65816 monitor with disassembler
Has anyone any experience or comment on Stephen L. Judd's Jamaicamon aka Jammon?
It is an approx 8k monitor for a 65816 system featuring a disassembler which handles 65816 opcodes and featuring breakpoint and single-step. Unfortunately it is built for the C64 SuperCPU addon, for which I can find no emulator or documentation, so porting to any other system seems daunting.
It might be comparable to Daryl's SysMon for the SBC-3 (which is much bigger but is self-contained)
http://www.ffd2.com/fridge/jammon/
http://sbc.rictor.org/downloads.html
Oops, it's starting to look like the SuperCPU merely runs an uploaded copy of the C64 kernal. So a reference to that would be appropriate:
http://home.swipnet.se/~w-59769/tasm/c64-diss.htm
http://www.ffd2.com/fridge/docs/c64-diss.html (broken internal links)
8BIT
Post by 8BIT »
My Sysmon does include a disassembler, but does not support breakpoints (other than BRK support) or single stepping.
If you remove the SBC-3 specific I/O routines, the monitor with xmodem support is just under 5k. If you remove the xmodem support, its under 4k in size.
That's great - 5k should work well for me!
Thanks
