6502 Klaus Test Program
Klaus2m5
Re: 6502 Klaus Test Program
Post by Klaus2m5 »
Hi Bill,
the part of the test for BRK functionality is conditional if ROM_vectors = 1. However on the last update 12-2017 I had accidentally removed the condition for the actual interrupt service routine and that would still try to assemble with reference to the calling BRK test. I will attach a temporary fix for this. Let me Know, if that works for you or wether there are any other issues.
cheers, Klaus
65C02_extended_opcodes_test.zip
(14.79 KiB) Downloaded 88 times
plasmo
Post by plasmo »
Thank you for the quick fix. It assembled without error and when loaded into CRC65 and ran from 0x0400 it displayed
Started testing
All tests completed, press R to repeat
Started testing
All is good, thank you!
