It is currently Sat Nov 23, 2024 12:46 pm
PostPosted: Tue Nov 17, 2020 4:04 pm
I was wondering if anyone knows of a development board for working with the ATF1508? Just something that had the pins out on headers and easy programming with the JTAG cable?
Something breadboard friendly would be nice.
BTW, I found this but it's way too expensive for what I want.
https://www.digikey.com/en/products/det ... AZhgBVajSA
PostPosted: Tue Nov 17, 2020 4:48 pm
I have built a break-out board for the ATF1504
File comment: ATF1504 Breakoutboard
And use a ATDH1150USB-K ISP Cable to program it in circuit.
I have also one of these
File comment: PLCC-84 Breadboard Adapter
But it is very time-consuming to connect all 84-pins.
In most cases a ATF1504 is enough to test new things and then I just copy the code over the ATF1508 in the final design
Peter
PostPosted: Tue Nov 17, 2020 5:07 pm
I happen to have one of those, along with several adapters. I haven't used it nearly as much as I thought I would.
PostPosted: Tue Nov 17, 2020 6:21 pm
Ditto
Andrew Jacobs
PostPosted: Tue Nov 17, 2020 6:51 pm
Thanks guys. Yeah, my parts bin is full of kits and boards I thought I would use more. lol
Which is why I'd like to go a cheaper route. Now, I do have a PLCC-84 to DIP board but it's not vertical. Which means it takes about 20 square feet of breadboard. lol
Ugh. I may just layout a small board myself and just have it made. Shouldn't cost too much.
@cbscpe
Do you have any of those to sell?
PostPosted: Fri Nov 20, 2020 11:13 am
I have spare ones. Just drop me PM with your postal address so I can send two of them to you (it's a give away)
Peter
PostPosted: Fri Nov 20, 2020 2:03 pm
Thank you! I certainly don't mind paying.
PM on the way.
