LLVM for MOS update 2020.08.19
Re: LLVM for MOS update 2020.08.19
johnwbyrd wrote:
I don't understand what a "section target specific flag" is.
cjs wrote:
Clever comments aside, this is really great work, and I'm really happy to see it all easily available on GitHub. The only suggestion I would make there is to move all that great documentation in the wiki into `.md` files in your repo instead, so that pulling the repo gets the documentation, too, and so it's easier to track changes to it and to keep the code and documentation updates together. (Markdown files in a repo can be browsed and searched in pretty much the same way as the Wiki; see, e.g., my sedoc repo for an example.)
I'm aiming to make this port part of LLVM proper someday, and as such I am trying to rigidly follow LLVM coding and documentation standards during development. LLVM uses Sphinx internally for documentation, not Markdown.
Things are in such flux with llvm-mos right now, that I figured it would be best just to document it wiki style until it becomes feature complete.
I intend to be fairly loosey goosey about letting others make changes to the wiki, if anyone feels that they need write access.
White Flame
Does LLVM have different classes of registers that it can handle differently? Because maybe you could define zeropage as a set of 256 registers. Just a random thought.
(Somewhat parenthetically: the small fly in the ointment of 'zero page as 256 registers' is that zero page is 256 bytes. And yet commonly zero page is used to store addresses, for the use of indexed modes, and there's room for 128 of those. And then, they don't need to be aligned. So it's a bit more subtle than a big byte-wide register file. Not that I've ever dealt with the internals of a compiler.)
White Flame
Sure, but some other architectures deal with somewhat related issues, like AX overlapping with AH & AL on 8086. But yes, that's different than the 16-bit vector (zp04) overlapping with (zp03) and (zp05), and the fact that a single 8-bit zp location is part of 2 simultaneous vectors.
On reflection, it wouldn't hurt too much, I think, to insist that pointers should be aligned.
The other thing that might be a problem when treating zp as a register file: when programming in assembly by hand we really seldom treat it as registers. There are virtually no scenarios where a data from memory would be transferred to zp, manipulated and then written back - and that's the way registers work. We even don't have special instructions that does stuff on zp explicitly. It's just a memory that is faster and has additional usage - to store pointers. So I'm afraid that tuning the compiler to tread zp as registers could produce ridiculous scenarios of transferring data between zp and memory hence and forth.
laoo wrote:
Obviously it's possible to do what you are describing; that's not in question.
However, the documentation at https://sourceware.org/binutils/docs/as ... ml#Section shows that there are no processor-specific flags currently present in LLVM.
My ultimate goal with this project is to submit it upstream for eventual inclusion in LLVM proper.
To do that, it will be absolutely necessary not to change the semantics of existing functionality in the assembler or the compiler.
This is entirely possible. Please see the AVR backend in LLVM, which took great pains not to break or change anything in the main LLVM body of code.
Adding a new processor-specific flag in the .section command makes it less likely that the work will ever be upstreamed.
Please give the .zeropage section flag a try, and let me know how it works for you. If that does not work for some reason, let's figure out a solution together that does not affect current gas semantics.
Please see also https://github.com/johnwbyrd/llvm-mos/wiki/Philosophy
We're going to sidestep this whole problem by treating a contiguous range of zero page as LLVM virtual registers.
https://github.com/johnwbyrd/llvm-mos/w ... n-thoughts
In practice this does mean that LLVM generated code will move all code from 16-bit memory to 8-bit memory before doing math operations on it and then pushing it back to 16 bit memory. However, I'm expecting that giving LLVM a plentiful range of virtual registers, should allow it to be smarter about what to cache there, and will hopefully avoid thrashing.
Really, this is no different from what most modern 6502 programmers do: they move memory to zero page before multiplying or doing multi-byte operations anyway. Although it seems wasteful to move memory back and forth, it works out to a net performance win because the instructions are so much faster and smaller when working on zero page.
If it does turn out that the memory thrashing is pessimal in some usage cases, I'm sure we can create an LLVM pass to reduce it. But we should deal with that problem when it becomes a bottleneck and not before. Premature optimization and all.
Link-time code generation will, I strongly suspect, be incredibly important for the 6502. As many others have recognized, C stack operations are performance killers on the 6502. In principle, LLVM can simply optimize most or all of them away, if it's able to see the entire program at once at link time.
After reviewing how clean your section specific zero page flag implementation was, I changed my mind and admitted it into the repository. Clean code is always the best possible argument.
On the other hand, when I have an optimized library routine this uses zeropage and you'd have to copy data there.
I'd keep the "fast variables" in zeropage, without needing to copy them back and forth. Maybe there is a way to "pin" these "registers" so backing storage in 16bit is not needed?
Other stuff that does not need to be as fast, I keep in 16bit memory even, without the need for copying it around.
