FLEX for the 6502 or building a compatible operating system.
Re: FLEX for the 6502 or building a compatible operating sys
Another set of tests, this time of adding variables.
Note that a planned future enhancement will place as many variables as possible in the zero page.
The lesson is clear: for best results, use unsigned variables whenever possible.
00080 ; 00001 program Test;
00081 ; 00002
00082 ; 00003 var
00083 ; 00004 B : byte;
00084 ; 00005 B2 : byte;
00085 ; 00006 Ch : char;
00086 ; 00007 Ch2 : char;
00087 ; 00008 I : integer;
00088 ; 00009 S : shortint;
00089 ; 00010 S2 : shortint;
00090 ; 00011 W : word;
00091 ; 00012
00092 ; 00013 begin
00093 ; 00014 W := W + S;
0B09 18 [2] 00094 clc
0B0A AD 10F9 [4] 00095 lda W_
0B0D 6D 10F8 [4] 00096 adc S_
0B10 AA [2] 00097 tax
0B11 AD 10F8 [4] 00098 lda S_
0B14 09 7F [2] 00099 ora #$7F
0B16 30 02 (0B1A) [2/3] 00100 bmi 2f
0B18 A9 00 [2] 00101 lda #0
0B1A 00102 2:
0B1A 6D 10FA [4] 00103 adc W_+1
0B1D 8E 10F9 [4] 00104 stx W_
0B20 8D 10FA [4] 00105 sta W_+1
00106 ; 00015 W := S + W;
0B23 18 [2] 00107 clc
0B24 AD 10F8 [4] 00108 lda S_
0B27 6D 10F9 [4] 00109 adc W_
0B2A AA [2] 00110 tax
0B2B AD 10F8 [4] 00111 lda S_
0B2E 09 7F [2] 00112 ora #$7F
0B30 30 02 (0B34) [2/3] 00113 bmi 2f
0B32 A9 00 [2] 00114 lda #0
0B34 00115 2:
0B34 6D 10FA [4] 00116 adc W_+1
0B37 8E 10F9 [4] 00117 stx W_
0B3A 8D 10FA [4] 00118 sta W_+1
00119 ; 00016 W := W + B;
0B3D 18 [2] 00120 clc
0B3E AD 10F9 [4] 00121 lda W_
0B41 6D 10F5 [4] 00122 adc B_
0B44 AA [2] 00123 tax
0B45 A9 00 [2] 00124 lda #0
0B47 6D 10FA [4] 00125 adc W_+1
0B4A 8E 10F9 [4] 00126 stx W_
0B4D 8D 10FA [4] 00127 sta W_+1
00128 ; 00017 W := B + W;
0B50 18 [2] 00129 clc
0B51 AD 10F5 [4] 00130 lda B_
0B54 6D 10F9 [4] 00131 adc W_
0B57 AA [2] 00132 tax
0B58 A9 00 [2] 00133 lda #0
0B5A 6D 10FA [4] 00134 adc W_+1
0B5D 8E 10F9 [4] 00135 stx W_
0B60 8D 10FA [4] 00136 sta W_+1
00137 ; 00018 W := B + B;
0B63 18 [2] 00138 clc
0B64 AD 10F5 [4] 00139 lda B_
0B67 6D 10F5 [4] 00140 adc B_
0B6A AA [2] 00141 tax
0B6B A9 00 [2] 00142 lda #0
0B6D 69 00 [2] 00143 adc #0
0B6F 8E 10F9 [4] 00144 stx W_
0B72 8D 10FA [4] 00145 sta W_+1
00146 ; 00019 W := S + B;
0B75 18 [2] 00147 clc
0B76 AD 10F8 [4] 00148 lda S_
0B79 6D 10F5 [4] 00149 adc B_
0B7C AA [2] 00150 tax
0B7D AD 10F8 [4] 00151 lda S_
0B80 09 7F [2] 00152 ora #$7F
0B82 30 02 (0B86) [2/3] 00153 bmi 2f
0B84 A9 00 [2] 00154 lda #0
0B86 00155 2:
0B86 69 00 [2] 00156 adc #0
0B88 8E 10F9 [4] 00157 stx W_
0B8B 8D 10FA [4] 00158 sta W_+1
00159 ; 00020 W := B + S;
0B8E 18 [2] 00160 clc
0B8F AD 10F5 [4] 00161 lda B_
0B92 6D 10F8 [4] 00162 adc S_
0B95 AA [2] 00163 tax
0B96 AD 10F8 [4] 00164 lda S_
0B99 09 7F [2] 00165 ora #$7F
0B9B 30 02 (0B9F) [2/3] 00166 bmi 2f
0B9D A9 00 [2] 00167 lda #0
0B9F 00168 2:
0B9F 69 00 [2] 00169 adc #0
0BA1 8E 10F9 [4] 00170 stx W_
0BA4 8D 10FA [4] 00171 sta W_+1
00172 ; 00021 W := S + S;
0BA7 18 [2] 00173 clc
0BA8 AD 10F8 [4] 00174 lda S_
0BAB 6D 10F8 [4] 00175 adc S_
0BAE AA [2] 00176 tax
0BAF A0 00 [2] 00177 ldy #0
0BB1 2C 10F8 [4] 00178 bit S_
0BB4 10 01 (0BB7) [2/3] 00179 bpl 2f
0BB6 88 [2] 00180 dey
0BB7 00181 2:
0BB7 2C 10F8 [4] 00182 bit S_
0BBA 10 01 (0BBD) [2/3] 00183 bpl 2f
0BBC 88 [2] 00184 dey
0BBD 00185 2:
0BBD 98 [2] 00186 tya
0BBE 69 00 [2] 00187 adc #0
0BC0 8E 10F9 [4] 00188 stx W_
0BC3 8D 10FA [4] 00189 sta W_+1
I made a small "breakthrough" in hacking the TSC BASIC interpreter. The keyword table has finally been identified. It is encoded using the same algorithm as the command table. Each character is doubled, then biased by 26.
No obvious reason for doing this other than hiding the previously disclosed Easter Egg in the command table. It is not faster nor do they save any space in the table.
16A0 03409 L_16A0
16A0 74 84 8E 84 03410 fcb 'G'*2-26,'O'*2-26,'T'*2-26,'O'*2-26,0,1
16A4 00 01
16A6 74 84 8C 90 03411 fcb 'G'*2-26,'O'*2-26,'S'*2-26,'U'*2-26,'B'*2-26,0,2
16AA 6A 00 02
16AD 8A 70 8C 90 03412 fcb 'R'*2-26,'E'*2-26,'S'*2-26,'U'*2-26,'M'*2-26,'E'*2-26,0,3
16B1 80 70 00 03
16B5 8A 70 80 00 03413 fcb 'R'*2-26,'E'*2-26,'M'*2-26,0,5
16B9 05
16BA 7E 70 8E 00 03414 fcb 'L'*2-26,'E'*2-26,'T'*2-26,0,6
16BE 06
16BF 86 8A 78 82 03415 fcb 'P'*2-26,'R'*2-26,'I'*2-26,'N'*2-26,'T'*2-26,0,7
16C3 8E 00 07
16C6 78 82 86 90 03416 fcb 'I'*2-26,'N'*2-26,'P'*2-26,'U'*2-26,'T'*2-26,0,8
16CA 8E 00 08
16CD 72 84 8A 00 03417 fcb 'F'*2-26,'O'*2-26,'R'*2-26,0,11
16D1 0B
16D2 86 84 7C 70 03418 fcb 'P'*2-26,'O'*2-26,'K'*2-26,'E'*2-26,0,12
16D6 00 0C
16D8 82 70 96 8E 03419 fcb 'N'*2-26,'E'*2-26,'X'*2-26,'T'*2-26,0,14
16DC 00 0E
16DE 8A 70 68 6E 03420 fcb 'R'*2-26,'E'*2-26,'A'*2-26,'D'*2-26,0,15
16E2 00 0F
16E4 8A 70 8E 90 03421 fcb 'R'*2-26,'E'*2-26,'T'*2-26,'U'*2-26,'R'*2-26,'N'*2-26,0,16
16E8 8A 82 00 10
16EC 78 72 00 11 03422 fcb 'I'*2-26,'F'*2-26,0,17
16F0 6E 78 80 00 03423 fcb 'D'*2-26,'I'*2-26,'M'*2-26,0,18
16F4 12
16F5 84 82 00 13 03424 fcb 'O'*2-26,'N'*2-26,0,19
16F9 6E 70 72 00 03425 fcb 'D'*2-26,'E'*2-26,'F'*2-26,0,20
16FD 14
16FE 70 82 6E 00 03426 fcb 'E'*2-26,'N'*2-26,'D'*2-26,0,21
1702 15
I have been putting some development time into FLEX again. The first priority is rearranging the several components of the system to arrive at a set of configurations which work on the largest number of dissimilar 6502 systems.
The second is changing the API slightly to try to reduce the reloading of registers. The initial prototype expected addresses to be passed in registers A:X because that was how I kept a sixteen-bit number while doing calculations. By changing the calling convention to Y:X, I am saving up to about half of the register reload instructions.
Now I have a couple of questions:
How useful is it to not corrupt memory used by a program if the operating system is rebooted? Some 680x programs provided a warm restart entry point at $103; this may be useful to try to save data after a crash before a total clean restart. Is it important at all to preserve the contents of the Utility Command Space under the same scenario?
I have always thought that the "current drive" concept in CP/M and DOS was a much more convenient way to specify the "working" drive than using the ASN (assign) utility in FLEX.
Now that I have a platform for experimentation, I have prototyped a current drive mode for FLEX. Instead of the usual "+++" command prompt, it uses "0++" when drive 0 is the current drive and operating in current drive mode. The "1." command makes drive 1 the current drive.
The ASN utility will be modified to switch between the classic and current drive modes in addition to assigning drives in classic mode.
So is this a good idea or am I off in the weeds?
- GARTHWILSON
- Forum Moderator
On a classic 8-bit machine, crash recovery depends upon how much work I would lose. There was a saying, "Save early; save often."
But the temptation is always there to make "just one more" change before saving.
For maximum chance of recovery if it was critical, I would reboot the OS, mount a blank disk and save all of RAM. A core dump if you will. That gave me a chance for multiple attempts at recovery. Assuming that the act of rebooting does not clear RAM or otherwise corrupt it.
For something less critical, I would just try jumping to the "warm start" address of the application if it had one and try saving. Again to a blank disk so that I do not corrupt the previous good save or saving to a possibly newly trashed disk.
Otherwise, I take a break and then do it over, saving early and often.
- floobydust
- Corrupting memory. I've been using DOS/65 for quite a while now. I have found that it does not corrupt anything in the TEA area on a reboot. In short, I can exit DOS/65 to my Monitor using the GO command or simply hit RESET on the SBC. Entering DOS/65 again results in no memory overwrite in the TEA area... I can simply use the GO command and re-enter the program loaded in TEA and all is well.
- Utility Command Space... not sure on this one, as I'm not familiar with Flex. DOS/65 uses $100 as a warm boot and $103 as the entry to PEM. Of course, these only survive if you don't overwrite memory when rebooting the system.
- Active Drive. As CP/M used letters for drives (as did DOS and later MS OSes), it's a familiar prompt for CLI. Again... with DOS/65, the current version supports multiple users, so the default prompt shows ">A0" for the A drive and the default User 0. Change the User to 1 and the prompt changes to ">A1". Maybe this would be something to consider??
In any case, I'd be happy to try a version of Flex when you have it ready. As previously mentioned, my SBC has a Compact Flash interface and the BIOS uses 24-bit LBA access for Read and Write.
Also, in addition to that, I added in code to deliberately wipe RAM to a known pattern so I could wipe/fill RAM, then run up my BCPL VM, then if it crashed or went AWOL I could check to see if it was scribbling over bits of RAM it wasn't meant to. (The default was to put pattern in Bank 0, Pattern+1 in Bank 1, and so on for the 8 banks of 64K in the '816 system) The fill thing was handy to check that something wasn't expecting a particular value either - so it was easy to find something that worked most of the time, then fail at other times - if that something was expecting RAM to be zeros for example - ie. to make sure my code initialisations was working correctly.
It was handy for me when developing my BCPL VM to look at RAM sometimes after a reset, so I added stuff into my RubyOS to let me dump RAM to screen (as well as dump the current BCPL VM registers, but that's an application specific thing).
Some 6502 computers do but many do not since they are oriented toward people using them as a tool rather as an end in itself.
First, nice to hear that you're back to working on Flex for the 6502. Second, not sure if my input can help you that much, but here's some feedback.
I hated the CP/M user number concept, particularly the need to keep multiple copies of programs differing only in the user number. CP/M Plus (version 3) made some changes so that user numbers worked better, but I do not have much experience actually using that.
My tools can generate both Motorola and Intel hex files. Does your ROM burner allow hex files in which the load addresses jump around, meaning not in ascending address order? I do not have and will not be using a linker. The ultimate goal is to eventually be able to build and configure FLEX natively on a FLEX system. The 680x way is to build the several components ORGed at non-overlapping addresses, then concatenating the resultant binary files.
Have you given any more thought to how to get files into and out of the system? I still think that a way to image a partition of your CF card from or to a virtual disk in a file would be the easiest to use.
- floobydust
Thanks for the detailed reply... very good and informative.
I use a Dataman 40Pro Programmer... it will handle a wide variety of formats including Intel Hex, Motorola S-Record, binary, etc., so I think it should handle anything you can generate, including non-contiguous data. I currently load 3 different S-Record files into the software, then program the EEPROM. The code pieces are separate and include the BIOS, Monitor and DOS/65 modules.
As for moving data to the SBC, my Monitor can send and receive binary data via XMODEM-CRC over the console port. On download, it will automagically sense and decode Motorola S-record (S19) files on the fly. I can also specify an offset address, which allows me to download binary code for a ROM address range to a specified RAM address. This is handy, as I can update EEPROM code without removing the EEPROM, as my Monitor also provides the ability to program the EEPROM insitu.
I've since written a separate Flash Utility which can update the Monitor code insitu. I've got an early version Flash Utility for the BIOS, but that one is more tricky... it works, but doesn't reset the SBC... just goes into neverland forcing a hardware reset to get it back.
I had previously reported that Corsham Technologies was selling reproductions of SWTPC computer components. They have also produced a CPU board based on the 6502 to plug into the same types of systems.
Sadly, Bob Applegate passed away about a year ago after a long fight with cancer. I had never taken advantage of the opportunity to buy from him.
Frederic Brown, founder of Peripheral Technologies, has begun producing sort of replicas of some of the Corsham products. He is mostly a fan of 680x computers, so it is not likely that he will provide KIM or SYM products, but much of the SWTPC stuff is now available again along with his own line of .SWTPC reproductions.
https://peripheraltech.com/
I find his improved design for the 6502 CPU board very interesting. The SWTPC bus is generally limited to memory cycles at 2 MHz. His design runs the 6502 at much faster clock speeds along with ROM and RAM on the board to support that speed. Wait state circuitry makes the board compatible with the slower SWTPC bus speed.
BTW, I have been collaborating with Frederic. He has been able to run some of my 6502 code on his board. We are currently working to bring FLEX up on it.
- floobydust
Most interesting... is there a version of Flex that I could try to port to my 65C02 system? I'm now using a RAM based DOS/65 version that boots from an IDE drive. There is currently 56KB of contiguous RAM.
Unfortunately, I still do not have anything distributable, especially for adaptation to different hardware.
The current effort is to migrate to a new reference platform based on the upcoming Peripheral Technologies hardware.
Also,
* the API is still not totally nailed down
* you have expressed a desire to have FLEX reside in ROM
* a long-term goal is to eventually be able to walk a majority of well-behaved programs written for 6800 FLEX, so some research is still needed
Also,
