Overview of 6502-like cores, hard, soft, partial, overblown
Re: Overview of 6502-like cores, hard, soft, partial, overbl
Is the MOS 6500/1 represented? It's in the 1520 plotter, among other things.
Those used the same core as early 6502s, didn't they? Just a different bond-out to the pins.
Yes, it's a 6502 core, but it's a full uC, with ROM and RAM, like some of the other variants listed in the table:
https://e4aws.silverdr.com/hacks/6500_1/
kakemoms wrote:
MOS MPS6510 (1981) - 1&2MHz - 151 opcodes, external clock, 64KB address space, IRQ¤, AEC (Address/Databus Enable), 256Byte RAM, IO port
¤ The NMOS variant of 6510 has no NMI
The 6510 was used in the Commodore 64 which came out in 1982. The C64 had the RESTORE key wired through half of a 556 timer and an inverter then directly to the microprocessor's NMI line on pin 4.
