N2- wrote:
yes I have a 16 bit ISA passive backplain, yes sound cards and the like are one of the existing perhiperal cards I'd like to be able to communicate with.
I hope you have access to some highly detailed doc, describing (for example) what registers exist on the sound card, and the functions of the bitfields therein. Or would you find it entertaining to reverse-engineer those nitty-gritty details? Maybe that's part of the fun.
now that I'm taken a closer look at the 65c265 it seems like it would solve many interfacing issues
It's convenient -- but not a big deal, IMO -- that you don't need to add an address latch, because A23-A16 are already demultiplexed. Are there other interfacing issues which the '265 will solve for you?
HOWEVER employing some GAL chips seems like the way to get the bus signals needed for the ISA bus along with a latch for the high order byte on the bus.
Not sure if it'll be helpful, but FWIW
here is a post with an outline of one possible scheme for providing a 16-bit data bus. This scheme lets you generate both bus cycles with a single instruction (ie, with the m bit in the P register =0).
ETA:
if you were to (say) decode a high bank where you had no RAM into the right signals to go over the bus, then you effectively memory map the IO signals...
Yes, that sounds reasonable.
