and note that the NXP UARTs have a RESET that is active going positive, not negative, so you'll need an inverter from the standard reset signal for the 6502.
I think have have some spare pins on a G22V10 that I can use for that.
Also, I use a FTDI USB-UART adapter instead of a normal RS-232 level convertor. It interfaces directly to the UART and gives you a USB port for any computer... i.e., OSX, Linux or Windoze.
I have an FTDI adapter that I'm using currently, but I'm thinking ahead for when I have a PCB made. It seems like a DB-9 serial port would be more appropriate for a PCB than the raw UART lines. Correct me if I'm wrong.
Say what? He has a can oscillator in his shopping list. All that needs is the usual bypass capacitor, a 0.1 µF XR7 MLCC.
I'm not sure what you are referring to. I plan to have 0.1 µF bypass capacitors for all of the ICs. Does the can oscillator need a bypass capacitor from Vcc to Gnd as well? No problem if it does. I can easily add one.
You need five capacitors for the MAX238, four for the charge pump circuitry and one to bypass the device.
I was going to go with a 1 µF electrolytic capacitor as the bypass for the MAX 238, per your "INTERFACING THE NXP SC28L92 DUART" document. Sorry I forgot to include that in my shopping list.
BTW, I've done some testing and have determined that it is possible to use ceramic capacitors for this application. I used Kemet's part number C315C105K3R5TA, which is a 100 mil lead-spacing part that is approximately the same physical size as the tantalum part.
I'm going to show my ignorance here. Is there a benefit to using ceramic capacitors rather than tantalum? My decision to use tantalum capacitors for the MAX 238 charge pumps also came from reading your interfacing document.
I'm sorry, but I just don't know the characteristics of the various capacitor types in order to know when one would be more appropriate to use than another. Can the 0.1 µF bypass capacitors for all of the ICs be tantalum or should they be ceramic?
Thanks for the replies!
