so i don't really see the point of doing that unless i were to make an addon/Co-Prcoessor to an existing 6502 CPU
Extended 6502 Project (Logisim)
Re: Extended 6502 Project (Logisim)
rpiguy2 wrote:
For the sake of compatibility rather than adding multiplication and division as instructions couldn't you implement a 65816-like "Coprocessor" instruction and build them as peripherals? Or is that cheating? (once you add a coprocessor you can do all sorts of things, like widen the registers to avoid carries and store intermediate results, etc.)
- GARTHWILSON
- Forum Moderator
Proxy wrote:
What instruction may seem to be lacking are absent probably because they would not be used much and they're easily and efficiently simulated with other instructions, like BSR (branch to subroutine), or because they would require slowing the clock down (for a given silicon geometry), or would take too much expensive silicon real estate to justify the small benefit.
You don't need a fixed-location subroutine. The 65816's PER (Push Effective Relative address) takes whatever the current address is at runtime and adds the 16-bit offset that's in the instruction's operand, and pushes the result onto the stack. So then you can do:
PER $+5 ; Put return addr on the stack, then
BRL <subroutine_addr> ; branch relative long to the sbr.It works even if the program gets loaded at a different address each time, without re-assembling or re-linking.
I know you really like your 65816, but personally i'm currently more comfortable with my 8 bit data bus and a 16 bit Memory space.
one day when i get to 16 bits i'll be sure to look into some 65816 projects.
Even if you don't latch, decode, or use the 816's high address byte, and even if you left its accumulator and index registers in the 8-bit size, you'd still get a load of benefits. In fact, its extra instructions and addressing modes are available even if you leave it in 6502-emulation mode (although a few of them would not be very useful, like the memory-move instructions MVP and MVN since with 8-bit-only registers, they'd be confined to zero page).
Similar to the memory-mapped coprocessor idea, there's the set of large look-up tables at http://wilsonminesco.com/16bitMathTables/ for not just multiplication and inversion (which are useful for dividing, by multiplying by the inverse), but also have log, trig, square-root, and other functions. If you use the whole set, it's 2MB, which is only 1/8 of the 816's memory map but would require going through I/O or banking if you implement them on the '02. Even doing that on the '02 though, there's still a huge performance advantage.
AMD used to make a couple of FPUs that were supposed to sit on the data bus and look like I/O devices. They had their own internal register sets, and some operations took several hundred cycles to complete (though this was still a major improvement over pure software). This would be something much simpler than that, but capable of handling much wider values - as I said, the target is quadruple-precision floats.
http://www.cpushack.com/2010/09/23/arit ... n-and-now/
SWTPC also sold the MP-N, a card containing a National Semiconductor calculator chip.
https://deramp.com/swtpc.com/MP_N/MP_N_Index.htm
and to be honest i'm natually prone to abandon projects like these... manually programming nearly 256 instructions really isn't appealing to noone's surprise.
Don't be put off by other things! The '816 has nothing to do with your project. You have you own preferences and your own vision: what's important and how to do it.
- GARTHWILSON
- Forum Moderator
Proxy wrote:
I see your point, but it makes it sound like i should give up on the project since the '816 already seems to do very similar things...
Sure, definitely do it however you want. I would only encourage you to take advantage of the work already done by those who have gone before, who figured out what was most useful and how it balances out with things like silicon real-estate limitations, then decide how you'll modify their conclusions for your differing set of limitations and goals.
I think Bill Mensch did an outstanding job on the '816 design, but I think he could have done even better if Apple hadn't insisted that it be able to run legacy '02 code. They knew that the Apple IIGS would not have been accepted in the market if it could not run old Apple II software.
but then again, i have never made a Co-Processor nor have i worked with the 816 before...
I'm currently just very demotivated to continue this... I'll sleep over it.
The '816 is not a great example for a new project, because a new project won't have the same constraints or cost functions.
Proxy, it would be a great shame to see you retire from this project.
And for everyone else, including me, this could be a good lesson in the cost of relating new ideas always back to the same old ideas. Much better to read carefully where someone is coming from and what they are trying to do. Write for your audience, and aim to be encouraging. Adding a smiley does not entirely defuse a grenade.
- BigDumbDinosaur
A fellow I worked for for a number of years had some good aphorisms that apply here:
- In order to go forward you have to learn from the past.
Evolution, not revolution.
Don't reinvent the wheel!
That said, when someone suddenly gets a notion to add all sorts of bells and whistles to what is basically a (to more-or-less quote Bill Mensch) "a cost-sensitive processor" I have to ask them if they have studied the design they are aiming to make over. Using an aviation analogy, suppose I yank the engine, wings and tail off a Beech D17 and replace them with the engine, wings and tail from a P51 Mustang. Would my Beech D17 still be a Beech D17? Or, would it be a P51? (Would it even fly? Anyone brave enough to find out?
Much of what I have read in this topic is—and again I will be blunt—fantasy. Why encourage someone to take a path that likely will lead them to failure? Again using an aviation analogy, why not just encourage would-be aviators who have only a limited knowledge of aerodynamics to fully extend their arms, leap off a cliff and start flapping like hell? Even though just about everybody who has tried that has ended up punching a hole in the ground with their head, we can't be discouraging such folly, can we?
BTW, designing a math coprocessor for the 65C816 could make you rich and famous...well, famous, if anything.
- BigDumbDinosaur
No, BDD, it's not appropriate always to push the 816 as the best solution, and it's not consensus that it is a marvellous product.
If you've managed to discourage someone, it's a bit late to re-iterate all your points and then tell someone not to be discouraged. Far better to learn the lesson.
There are already threads about how and in what ways the 816 is an appropriate choice. The polite thing to do, when you have a hobby horse such as this, if you can't bear not to mention your favourite thing, is to post a simple link to a previous thread where all these points have been made.
This forum has a good reputation for being welcoming and helpful and good natured. Let's not spoil it by pushing every thread into the same direction.
Don't worry i get discouraged very quickly by about anything.
I'll still finish this though. mostly for the sake of finishing a project.
I have decided on the Instructions i want to add, there are 93 new opcodes. bringing the total amount to 244, leaving a total of 12 opcodes empty for any future use.
today i'll try to program them all in, once done i'll make an Opcode table that not only shows the opcodes but also compares their cycle times with the original instruction set.
- GARTHWILSON
- Forum Moderator
I find that when I suddenly get interested in a new field, I soak up all the information I can about it, and it quickly changes my perspectives and goals to ones that are more realistic and useful and valuable than the ones I started with.
- BitWise
- In Memoriam
One of WDC's soft core models has a memory mapped maths accelerator. You write the multiplier and multiplicand to memory registers and read the product from another location. You could do the same for division.
Andrew Jacobs
