dagenius wrote:
What would be the best assembler to use for the code? I had a look at the ASxxxx and from looking at the docs it's hard to tell what features it has. I'm looking for something that supports macros and works on Windows 10 or Ubuntu 18.04. Does anyone have any suggestions?
The things you'll want to think about include:
- Does it support the build platform you prefer to use (Unix, Windows, whatever), or do you have the other tools you need for the build platform on which it runs?
- If you have existing code, does the assembler support the assembler syntax used by that code? (For example, does it require you use or not use a colon after a symbol name when declaring a symbol, or let you use either option? Does it support the pseudo-ops the code uses? What macro and function capibilities does it offer to define new syntax that could be used to make it compatible with your existing code?
- Does it provide the output format you need, or can you easily find or write a tool to generate the output format you need?
- Who else do you know that's using it, and are there users of it in whatever forums you frequent? Especially when you're a beginner, it's helpful to have a source of support.
- Does it support the CPUs you're interested in, or may be interested in in the future?
- Does it have macros and other useful features?
Again, though, it doesn't matter that much. Rather than worrying about making the perfect decision now (which you won't be able to do anyway), use whatever seems best at the moment and be prepared to switch when it becomes necessary or convenient.
