Starting with my first SBC Project, Plans and Confusions
- BigDumbDinosaur
Re: Starting with my first SBC Project, Plans and Confusions
Proxy wrote:
I've been procastinating by mostly gaming but also by making this:
it should be kinda self explanatory. (i tried to avoid using too many or any colors. so it's mostly black/gray/white)
the only thing holding me back from ordering all the stuff is fear that i somehow still missed something... and i don't know how to work against that.
Interesting instruction tables. In the one for transfers, don't forget the stack as a memory addressing mode.
I would try structuring the opcode table with a different grouping of bits, which better reflects the way opcodes are internally decoded by the 6502. Broadly speaking there is an aaabbbcc pattern, which gets confused if you make the table "square" with an xxxxyyyy pattern. I think it makes sense to have rows with the aaa000cc bits, and columns with 000bbb00 bits.
there is a reason this xxxxyyyy way of ordering Opcodes is so common with 8 bit CPUs (including the 6502, as said even the offical datasheet does it like this (page 10)). it's just that good.
What's with all the 'X'es in the column and row headings?
other sites like these just use a 0 to represent the same thing, which i could do as well....
for example "AND zpg", you go to the left and it says "2X", you go to the top and it says "X5",
then you just add them together in your head:
2X
X5
= 25
Fixing layout mistakes is why bodge wire was invented.
- BigDumbDinosaur
I know how to read an opcode table.
It's the first time I've ever seen that sort of representation. Just about every opcode table I've perused in the last 50-odd years that refers to byte-size opcodes has a single digit in the headings. The opcode tables in the 65C02 and 65C816 data sheets are a good example.
i guess a good way would be something like this?
Nice project, I was just reading through and I learned something very useful, especially about the FT240X. This one will definitively go into my next 6502 project. No UART (buggy 65C51) required. Although I might have to add an interrupt controller.
Here some information about those mysterious special purpose input signals of the ATF1504 and other good to know things I always keep in mind when using CPLDs.
A CPLD is like a collection of GALs. The ATF1504 may be looked as four "40V16 GALs" (meaning you have a GAL with 40 inputs and 16 outputs, analog to the notation of 16V8 or 22V10). They are called "Blocks". However in the case of the CPLD you may use all inputs and outputs at the same time. Not like a 22V10 where using more than 12 inputs reduces the number of available outputs. In addition the internal GALs have some feedback logic. That is signals generated in a Block can bee feed back to the same block without using one of your 40 inputs. The 40 inputs selected from all possible signals using an input matrix attached to each block. You can see a report of the inputs selected by each block in the fitter report. This is called FAN-IN and is a limitation you cannot exceed. On the other hand no all outputs of the macrocells of a block are connected to a PIN. In the case of a ATF1504 in PLCC-44 or TQFP-44 eight macrocells are connected to PINs. This connection is not configurable (contrary to other CPLDs which also have an output matrix). So you need to be careful which pin is used as output for complex equations. I will come back to this later.
Also very important to know is that each macrocell has only five product terms. In a GAL22V10 you have between 8 to 16 product terms per output logic macro cell. If you need more product terms for an output you can either borrow product terms for the macrocell "above" from the same block. This requires that the macrocell above is not allocated to an output and is not in a different block. E.g. MC17 cannot borrow product terms from MC16. Also you can borrow product terms only for one equations.
Each macrocell has many configuration option. You can use product terms for boolean logic only, or in case you configure the macrocell as a register you can use product terms for clock, output enable, input, asynchoronous set and reset.
The global signals have the advantage that they do not consume any product term in a macrocell when they are used as a single input (e.g. not part of an equition for the .ar .oe or .ck input of a macorcell) and they do also not consume any input of the input matrix (do not count for the FAN-In signal). In other words using global signals can save a lot of product terms.
Global clocks are special as a registered macrocell has can also have a .ce (clock enable input) when the .ck (clock) input uses a global clock. This is often need in sychronous logic.
Statemachines can use any clock input. There is no need to use a global clock. However when you use a global clock you save a product term which may result that even large statemachines fit into the CPLD without feedback signals or borrowing product terms from the macrocell above.
As an example if you build a multiplexor with a tri-state output you can multiplex 5 input signals of you use a global output enable without using product terms for other macrocells. Else you can only multiplex 4 signals. You can always multiplex more signals, but that will use additional macrocells.
CPLD also support bidirectional pins. In this case you must refer to the .io extension of the pin-name, else it will use the internal value of the output of the macrocell (the tristate buffer comes after the output).
Peter
Peter
Proxy wrote:
the X basically means "don't care"...
If you'll excuse the colour coding, the attached is what happens when you do as I suggested. Large parts of the opcode map start to look organised.
just stick to the standard Opcode matrix/table that has been used from the start... it's common, and it works across different CPUs.
though i guess it's useful for finding what hex value a specific instruction has,
while the regular opcode table is more useful to find what instruction matches a given hex value.
so they kinda complete eachother...
Maybe this one is a bit easier to read, with extra header rows where the last digit changes:
basically you just have the 8 bit opcode split into 3 parts... so all you need is a table with 3 axes!
this means in order to properly display all opcodes and numbers in a ordered way you need a 3 Dimensional Table/Matrix, easy as that.
- BigDumbDinosaur
As long as I've been working with this stuff, convention has been like that seen on page 22 of the 65C02 data sheet.
I personally find it a bit weird that in this format one looks at the numbers on the right to get the left-hand digit, and then the column of numbers on the left to get the right-hand digit. I'm sure you get used to it if you use it regularly don't use tables that are the other way around.
In some recent Apple II hacking using the Autostart ROM (i.e., no mini-assembler) I've found it convenient to do hand-assembly from time to time. For that I came up with this table, which makes it (for me) easy to quickly find the opcode for the particular instruction and addressing mode I have in mind. (Warning: this has not yet been throughly proofread. I welcome corrections.)
JSR RTS JMP (JMP) BRK RTI NOP
20₆ 60₆ 4C₃ 6C₅ 00₇ 40₆ EA₂
BEQ BNE BMI BPL BCS BCC BVS BVC
F0₂₊ D0₂₊ 30₂₊ 10₂₊ B0₂₊ 90₂₊ 70₂₊ 50₂₊
CLC SEC CLV CLI SEI CLD SED
18₂ 38₂ B8₂ 58₂ 78₂ D8₂ F8₂
TAX TXA TAY TYA TSX TXS PHA PLA PHP PLP
AA₂ 8A₂ A8₂ 98₂ BA₂ 9A₂ 48₃ 68₃ 08₄ 28₄
zp addr zp,X aaaa,X
INX DEX INY DEY INC E6₅ EE₆ F6₆ FE₆
E8₂ CA₂ C8₂ 88₂ DEC C6₅ CE₆ D6₆ DE₆
#nn zp addr zp,X aaaa,X aaaa,Y (zp,X) (zp),Y
LDA A9₂ A5₂ AD₃ B5₄ BD₄₊ B9₄₊ A1₆ B1₅₊
STA 85₃ 8D₄ 95₄ 9D₅ 99₅ 81₆ 91₆
LDX A2₂ A6₃ AE₄ B6₄y BE₄₊
STX 86₃ 8E₄ 96₄y
LDY A0₂ A4₃ AC₄ B4₄ BC₄₊
STY 84₃ 8C₄ 94₄
ADC 69₂ 65₃ 6D₄ 75₄ 7D₄₊ 79₄₊ 61₆ 71₅₊
SBC E9₂ E5₃ ED₄ F5₄ FD₄₊ F9₄₊ E1₆ F1₅₊
CMP C9₂ C5₃ CD₄ D5₄ DD₄₊ D9₄₊ C1₆ D1₅₊
CPX E0₂ E4₃ EC₄
CPX C0₂ C4₃ CC₄
ORA 09₂ 05₃ 0D₄ 15₄ 1D₄₊ 19₄₊ 01₆ 11₅₊
AND 29₂ 25₃ 2D₄ 35₄ 3D₄₊ 39₄₊ 21₆ 31₅₊
EOR 49₂ 45₃ 4D₄ 55₄ 5D₄₊ 59₄₊ 41₆ 51₅₊
BIT 24₃ 2C₄
ASL 0A₂ 06₅ 0E₆ 16₆ 1E₇
LSR 4A₂ 46₅ 4E₆ 56₆ 5E₇
ROL 2A₂ 26₅ 2E₆ 36₆ 3E₇
ROR 6A₂ 66₅ 6E₆ 76₆ 7E₇Curt J. Sampson - github.com/0cjs
My PCBs have arrived but i think the parts from Mouser are gonna take a while.
So until i got the parts, the project is gonna be put on ice.
This doesn't mean i want to be inactive though.
for example i have already designed a "very simple" VGA circuit that fits onto a 5 EUR FPGA (a Lattice LCMXO2-640HC-4TG100C to be exact, though i was unable to test it on real hardware yet).
the idea behind it was to have a simple and cheap way of getting VGA video for any 6502 based computer without requiring people to design their own chip, or download GBs of FPGA software and learn Verilog and stuff.
I know others have done the same, but i think more choices = better for everyone.
another thing i also want to do is making my own expanded 6502 for future projects.
my main problem with that is that the status register is just confusing me really hard and i'm not 100% sure on what to put in it.
but I'll put that in it's own thread, not here.
I assume the "Emulation and Simulation" sub-forum would be the fitting place for that?
anyways, thanks for everyone here helping me out so far, i hope my future projects will be as interesting and useful for others as i somewhat hope they are.
i'll be back on this thread once i got my stuff.
The status register is just a bit of the chip that is almost fully automatic. Every time you do a load or arithmetic or logic operation the status register is automatically updated although the choice of mnemonics can be confusing to newcomers - check for zero is the same as check for equal (BEQ) or not zero (BNE). Some assemblers duplicate mnemonics or if using a macro assembler you can define your own, so you could define BZE to be BEQ and BNZ to be BNE and so on. (the ca65 'generic' macro package does this for example)
The automatic update of the status register saves you doing explicit checks in a lot of cases. It's also why you may see loops counting down to zero than up to a number too - when you decrement a register and it hits zero, then the zero flag is automatically set, so you don't need an explicit compare, so you save both clock cycles and code space.
Tell you what, when I get a spare moment I'll post a thread in the Programming section, to discuss the status register in detail.
