Mini-challenge: detecting activity on a port
Here's a mini-challenge for you. I have a real application in mind too, so it's not artificial.
You have an 8 bit input port at some absolute address, and the challenge is to write a subroutine which waits for every pin to toggle (change state) at least twice, and then returns. (It should of course return as soon as every pin has toggled twice, regardless of the starting state of the inputs and the order in which they toggle. They might all change together, or one by one.)
For example, if the port initially reads 00, then the next read is FF, and the next read is 00, we're done. Or if the first read is 01, then 02, shifting left to 80, then 01 again, we'd be done. Or it might take thousands of samples: it might even never happen. There might be many repeated values, or no repeats at all.
Edit: adding a bit of padding to keep replies further down the page...
Re: Mini-challenge: detecting activity on a port
Oh, this looks fun! My approach would use three bytes of ZP; one maintaining the previous state of the port, and two masks indicating whether the first and second transitions have occurred on each bit; I think that's the minimum required to function. And I'm going to use CMOS instructions. This is 34 bytes, or 32 if you leave out the early loopback which reduces port response latency. One further byte can be saved at a slight speed penalty by inverting the polarity of the second register: The above is 31 bytes. This form is also easier to convert to be NMOS compatible, by replacing each TSB with ORA/STA and doing the usual fix on STZ, but this adds 6 bytes to the code size and 2 cycles to the sampling interval.
In the first example, the port is sampled every 12 cycles if it hasn't changed in any bit, with a gap of 37 cycles if it has. If the short-circuit is removed, the sampling interval becomes a consistent 35 cycles. The second example takes 37 cycles consistently. These characteristics will define timing requirements for the external hardware, in terms of the shortest pulse that will consistently be detected; at 8MHz CPU clock, 40 cycles (5µs) might be considered safe.
port = $xxxx
zp = $zz
prev = zp+0
first = zp+1
second = zp+2
WaitPort8:
; initialise
LDA port
STA prev
STZ first
LDA #$FF
STA second
; main loop
: LDA port
TAX
EOR prev
BEQ :- ; speed optimisation, omit if size critical
STX prev
TAX ; mask of changed bits
AND first ; bits that have already changed once; this is their second
TRB second ; clear them out of the terminating condition
TXA ; return to bits just changed
TSB first ; record that fact
LDA second ; now test to see if all flags cleared
BNE :-
RTS
port = $xxxx
zp = $zz
prev = zp+0
first = zp+1
second = zp+2
WaitPort8:
; initialise
LDA port
STA prev
STZ first
STZ second
; main loop
: LDA port
TAX
EOR prev
STX prev
TSB second ; set them in the terminating condition
LDX second ; now test to see if all second flags set
INX
BNE :-
RTS
rudla.kudla
Same idea here. 6502 instruction set.
ch_1 = 129
ch_2 = 130
org $2000
START
lda #0
sta ch_1
sta ch_2
lda test
sta prev
ldy #1
@ lda test,y
jsr REGISTER
iny
cpy #test_end-test
bne @-
loop jmp loop
rts
REGISTER
tax
eor prev
stx prev
tax
and ch_1
ora ch_2 ;leave only those, that were previously set to 0
sta ch_2
txa
ora ch_1 ;accumulate 1 bits
sta ch_1
;##TRACE "%08b %08b %08b" db(prev) db(ch_1) db(ch_2)
lda ch_2
cmp #$FF ;Z = 1 - done
rts
test
dta %00000010
dta %00000011
dta %00000001
dta %00000111
dta %00000110
dta %00000100
dta %11111000
dta %00000000
test_end
leepivonka
WaitFor2Changes:
lda port ; remember initial values
sta @orig
stz @change1 ; no 1st changes yet
stz @change2 ; no 2nd changes yet
@loop:
lda port ; get changes
eor @orig
sta @temp1
ora @change1 ; accum 1st change
sta @change1
eor @temp1 ; accum 2nd change
ora @change2
sta @change2
ina ; until all 2nd change set
bne @loop
rts
@orig: .byte ; original value
@change1: .byte ; 1st change seen
@change2: .byte ; 2nd change seen
@temp1 .byte ; temporary
That is an interesting alternative approach. Essentially you're looking for bits to be set and then cleared, after first transforming them relative to the first value read, rather than explicitly looking for two changes between successive reads. It's potentially a little smaller code than mine, but requires an extra byte of storage.
As written, it would end up quite large because of the locally-allocated storage (which requires absolute addressing). If you move the variables into ZP, it's 30 bytes.
- commodorejohn
Oh, interesting...gonna have to have a think on this one.
Hi!
This kind of problem (having to perform logic for all bits in a byte/word) can be solved by a technique called "vertical counters", see https://everything2.com/title/vertical+counter for a little explanation.
In your case, you can define a state machine with three states, representing the number of transitions seen, state A, B and C. You got from A to B of from B to C if you detect a transition, and do nothing in all other cases. If you encode with two bits, "x" and "y", using A = "00", B = "01" and "C = "11", your logic table is:
This simplifies to the two equations: x' = x+I*y and y' = y + I.
Now, the (untested) code:
Have Fun!
In xy x'y'
0 00 00
0 01 01
0 10 --
0 11 11
1 00 01
1 01 11
1 10 --
1 11 11
' Three ZP locations for our variables:
OLD_IN = $10
S_X = $11
S_Y = $12
wait:
' Init old input var
lda INPUTS
sta OLD_IN
lda #0
ldy #0
loop:
' Store state
sta S_X
sty S_Y
' Check toggled bits updating old value
lda OLD_IN
tax
eor INPUTS
stx OLD_IN
' Store for later
tax
' Now, get new Y
ora S_Y
tay
' And the get new X
txa
and S_Y
ora S_X
' Compare X with 255 (al bits set)
cmp #255
bne loop
' Ok!
rts
I count 35 bytes, 38 cycles per loop, and at least one visible bug…
Otherwise, it's conceptually similar to my solution, just implemented differently.
Hope everyone's having fun! Great to see the code posted. (For myself, I think my vague idea was to register rising transitions in one byte's worth of bits, and register falling transitions in another. When both of those bytes fill up we're done. But I hadn't written any code. There's always more than one way to do it!)
LDA port
STA prev
LDA #$FF
STA first
STA second
: LDA port
TAX
EOR prev
AND prev ; falling transitions have bits set
TRB falling
TXA
EOR #$FF
ORA prev ; rising transitions have bits cleared
AND rising
STA rising
STX prev
ORA falling
BNE :-
RTS
Hi!
Yes, I saw your code after posting mine, I tried to show how to arrive at a generic solution because I have used vertical-counters in microcontrollers before, for debouncing and general counting of transitions.
Also, my code is 6502 only, and I still don't see the bug yet
Have Fun!
Have Fun!
Hi!
Now I see it, fixed code bellow:
Have Fun!
dmsc wrote:
Hi!
Have Fun!
Have Fun!
OLD_IN = $10
S_X = $11
S_Y = $12
wait:
lda INPUTS
sta OLD_IN
lda #0
ldy #0
loop:
' Store state
sta S_X
sty S_Y
lda INPUT
tax
eor OLD_IN
stx OLD_IN
' Store for later
tax
' Now, get new Y
ora S_Y
tay
' And the get new X
txa
and S_Y
ora S_X
cmp #255
bne loop
' Ok!
rts
- barrym95838
I haven't tried to analyze anyone else's code yet, and started with a clean sheet of paper and a #2 pencil (I'll be using the NMOS instruction set obviously) ...
I don't have any time to test it, because I'm sneaking it in at work, but it looks like I did it in 30 bytes +RTS +two bytes of ZP. I'll try to test it tonight, but I would certainly appreciate any early feedback from you guys. Thanks,
attempt:
lda #0 ; initialize bit trackers
sta once
tax
cont:
sta twice ; track bits that flipped >= twice
txa
ora once ; 1s for bits that flipped >= once
sta once ; track bits that flipped >= once
ldx PORT
wait:
txa
eor PORT ; wait for some PORT activity
beq wait
tax ; 1s for bits that flipped this time
and once
ora twice ; 1s for bits that flipped >= twice
cmp #$ff ; have all 8 bits flipped >= twice?
bne cont
rts
Hmm, I spy a race condition in that last one. When any bit transition is seen, any future transitions are only detected relative to a second port read. So any transitions occurring between those two reads will be lost.
- barrym95838
I must be a bit confused or near-sighted, because I don't immediately see how I'll miss any port transition events unless they burst less than ~30 cycles apart, which is about how long my routine takes to allegedly close its eyes to digest each event. I guess I'll have to try to grok what the rest of you have posted to see where I failed ...
Would this one have a smaller "blind spot"? (it's one byte smaller too, and still NMOS, baby!)
attempt2:
sta once
cont:
beq first
txa
tya
eor PORT ; check for PORT activity
first:
ldy PORT
and once
bne cont
rts
