Identifying what 6502s from Aliexpress really are
Re: Identifying what 6502s from Aliexpress really are
we will need the schematics and ideally a photograph.
It's pretty hard to theorise without knowing what techniques you've used, both logically and physically.
- BigDumbDinosaur
I'm pretty sure you posted a colour schematic earlier this year BDD!
As was already mentioned, Atlantis...
Schematics and photos of my computer are posted HERE
I do not see any reason why some won't work with it. Of course assuming they are fine and not compromised in some wired way, that allows them to run NOP test with proper result.
Well... Only one thing came to my mind. I designed CPU board in a way that two SRAM chips, EPROM and address decoder are connected directly to the CPU address bus. I assumed it wouldn't be too much of a load (SRAM is CMOS, address decoder is built with HCT chips). I added 74HCT245 buffors just before system bus connector, so all the chips on the second board are buffored.
There are bypass capacitors and electrolytic/tantalum capacitors present on my boards.
Oh yes, that thing. I see it's configurable to run at 1MHz or 2MHz, which is not too ambitious, so the basic PCB design technique shouldn't be a problem. But the clock generator uses 74LS chips in the schematic, which would not be a good fit for a CMOS CPU. And the BE pin is not pulled up, which may disable some of the more advanced 6502 variants; short it to /SO as an expedient. In fact, I would swap out all 74LS logic for 74HCT as an early troubleshooting step.
Is is there remote possibility that it can be load issue? Because of 2xSRAM and EPROM connected directly to address bus?
All 6502s have at least as much drive capability as the NMOS ones, which have an LSTTL-like asymmetry in their drive due to the depletion-mode N-type pullup transistor. The CMOS ones can pull up much harder.
But I do see some 74LS chips on your board in the photograph, and those will definitely have inferior drive and load characteristics to 74HCT. I seriously do recommend eliminating them from your build.
- GARTHWILSON
- Forum Moderator
I had to look through the last few pages to figure out which ones you're saying aren't working. From page 2 of the topic, it looks like it's CMOS ones that aren't working. If that's what you're asking about, the answer is that the pin drivers of any CMOS 65c02 are much, much stronger than those of the NMOS 6502. From http://wilsonminesco.com/NMOS-CMOSdif/#hdwr :
- CMOS has stronger bus-drive capability, far stronger than the datasheets let on. I have done some brief tests on WDC's W65C816S's pin drivers which I suspect are the same ones used they used on the W65C02S. Their behavior was pretty much symmetrical, able to pull up just as hard as they can pull down, unlike TTL which cannot pull up as hard as down. If you had to boil my test results down to approximations and treat the circuits as just a resistance, the data pin drivers acted very roughly like a SPDT switch with 50Ω in series with the common terminal (ie, the output); and the address bus pins, as a SPDT switch with 60Ω in series. The time constant of 60Ω times the capacitive load of 10 CMOS loads is around 3ns, which is less added delay than you'll get from a bus transceiver IC.
In a separate test on WDC's W65C22S VIA (not the W65C22N) I/O pins years earlier, I found they were each able to pull to within 0.8V of either rail with a 220-ohm resistor to the opposite rail, meaning a 19mA load, even pulling up, and give 50mA into a dead short. Rockwell's R65C22 could pull down with 100mA into a dead short, but could not pull up as hard, not being symmetrical like WDC's.
So no, you definitely do not need bus buffering with a 65c02. It's plenty strong without them.
Conversely, the CMOS CPUs will likely be more sensitive to the voltage levels on input. Generally a CMOS device will prefer to see CMOS-like rail-to-rail inputs, rather than TTL-style inputs which may be a valid high as low as 2.4V. It is of course possible to make a CMOS input that is TTL-compatible - that's what the 74HCT series is all about - but some of the CMOS 6502s don't have this.
- GARTHWILSON
- Forum Moderator
I think most of the non-WDC 65c02's will accept 2.4V as a logic high, whereas WDC's are rated for anywhere from 1.2V to 5.5V power supply and want 70% of Vcc for a logic high (according to the data sheet).
Atlantis wrote:
Those "mysterious" 6502s running fine with NOP test on breadboard but not working with my computer were tested with standard configuration, without this pin pulled up.
Not sure what you mean by standard configuration, but all the newer CMOS CPU's do need the pin pulled high. You can't standardize on the old pinout, I'm afraid.
Whoa, wait... Atlantis, do you mean on your computer that pin is still not pulled up? That would explain a lot!
To be sure we talk about the same thing, let me explain once again:
1) I bought some 6502 CPUs from different sellers on Aliexpress. Those chips supposed to be NMOS or CMOS R65C02. Not WDC version. Most likely they were relabeled anyway...
2) I tested them in my computer and found out that some of them do not work properly. EhBasic doesn't initialize, there is no activity on serial terminal.
3) I performed NOP test on chips that failed previous test (inside computer). I used breadboard and wired it for standard NMOS/R65C02 chips (which they supposed to be), so no BE pin being bulled up. And yes, I used 74HCT74 on my breadboard.
4) Some (six to be precise) of those CPUs passed NOP test on breadboard, however they were unable to work inside my computer. I am trying to figure out why.
It can't be because of lacking pull-up on BE pin, because:
1) They are running NOP test on breadboard, despite the BA pin not being pulled up.
2) There not suppose to be a BA pin anyway. They were bought as NMOS parts.
Consistent with the title thread, if they *do* start working reliably when the BE pin is actively pulled up, then you've identified them as functioning 6502s - but that are not quite the model you expected. It wasn't just Rockwell and WDC making CMOS 6502s, and quite a few of the variants have either a BE or DBE pin.
The thing is, you can't assume that a pin is pulled low just because you didn't pull it high. Especially on CMOS inputs, if you leave it floating it can take on any value and even pick up crosstalk from nearby signals. It would not be at all unusual for it to do something different when put in a different circuit. So I really do think you have a BE pin on these "flaky or non-functioning" CPUs. Testing them with BE tied high will let you figure out which.
Just to note, Atlantis, you are observing that a chip works in a NOP test but does not work in your computer. There's a whole spectrum in between those two extremes - it's not wise to think of a NOP test as a gold standard. It's just the simplest possible test.
If you have any old commercial 6502 computers with a socket for the 6502, and if you are fairly confident that the chip you wish to test is the same pinout as the computer expects, then using that computer as a test is a physically simple thing to do which will put the 6502 through a fairly complex test.
I've seen problems in the past where a 6502 didn't put out a SYNC signal. In almost all applications, that wouldn't matter, but in this case it did. One can imagine that a faulty NMI input would also work in many situations but certainly not all. A faulty RnW output would cause a 6502 to run the NOP test happily but fail to work in pretty much any other application. And so on.
This is strange...
Can I leave BE 3,3k pull-up resistor there, even if I intend to use NMOS CPU? Will it be safe for NMOS version of 6502?
