the microsemi MT8952B seems to be originally intended as an ISDN x.25 controller for the d-channel and to be interfaced with motorola 6809 controllers (also usually in isdn terminal adapters
it does however seem to do all the things the MC6854 Advanced Data Link Controlle (no longer in mass production), furthermore never was available rated for more than 2mz) also does.
i'd say it's a pretty good candidate for either a bus network topology simple, standardized network to be used with 8 and 16 bit microcomputers and microcontrollers.. (for example when combined with canbus linedrivers)
besides that it seems to have it's uses for packet and tactical radio TNCs (it does the whole NRZI bit stuffing and framing that upon first glance over the datasheet seems 100% compatible with ax.25)..
(besides that it can turn the bitstuffing off and after that it's simply a really fast uart...not entirely sure on the bit order on the line tho. it might not simply be rs232 at a higher bitrate in 'transparant mode'
(As for use in econet, i'm not sure wether econet uses NRZI bittstuffing at this point, it most likely does)
(and yes it's 5.25V and pdip and parallel bus and i -think- it should work with 65xxx cpus just as well)
has anyone ever used these things with 65xxx ? or for any other purpose than building isdn equipment? (you can basically chunk out network cards for pretty much any commodore, atari, acorn, etc product at less than 10 dollars each using these chips - it won't be ethernet but those computers can't handle 10mbit anyway and the cs9800a doesn't have workiung irq's in 8-bit mode so this is probably better... 1 or 2 mbit should suffice. 160kbit would even be better than 'nothing'). (as for the tacical radio communications, 1200 baud is still standard, 9600 optional, and 38400 very very fast to this very day
the bus timing in the datasheet seems a bit 'off' compared to 65xx family chips (address and databus lines don't seem to -need- to have the desired state at the same time and for some reason it can be clocked on 'cs' or on 'e' but has no actual 'clock' pin but i guess it should basically just work in a new 65c02 or 65815 board or old microcomputer.
