Looking for Baum's tiny assembler on Apple-1
I remember I've read somewhere that in 1976 Allen Baum had written a tiny 300'ish byte assembler for the Apple-1. It supposedly uses a clever brute-force method, parasitising on the Baum-Wozniak disassembler (so that must be present as well, but that's just under 500 bytes).
However, after much googling, I can't find the actual code. Did I misremember?
I can find the infamous disassembler. It was published in Dr. Dobb's and I've got it running fine in the Gigatron's Apple-1 emulator. Now I would like to add an assembler as well.
Any pointers are much appreciated.
P.S: I'm not looking for something like KRUSADER. Just something small. In order to be useful for this project, it will have to sit somewhere of the $400-$fff area in the Apple-1 memory map.
Re: Looking for Baum's tiny assembler on Apple-1
Indeed this may be it. However, it appears to call out to a whole bunch of functions not present in the Apple-1. Perhaps I misremember the story and this assembler doesn't exist for Apple-1.
In the meantime I stumbled upon this:
http://www.apple1notes.com/old_apple/Mo ... _on_1.html
This is a very interesting approach provided I can get it to sit in $0500-$0fff. That link gives hex files for several starting addresses, but not this range. Perhaps I can XOR two of them to get the one I need
[...] As a part of the material in the Gayler collection was a program tape that contained a file of the Apple II monitor ported to the Apple 1 that he had apparently made complete with Mini-Assembler. This was not a transitional step from the Apple 1 like the Monitor file by Steve and Allen but a port of the completed Apple II monitor including the mini-assembler. [...]
Good find! Certainly should be straightforward to find the variant bytes and use that to relocate.
Source code for all the Apple 1 and Apple II monitor is out there - including the source code for the mini assembler.
e.g.
This link might help: https://github.com/cmosher01/Apple-II-S ... tag/v1.1.2
So if you can assemble that then you can relocate it anywhere - and have it use your own IO, etc. routines.
e.g.
;* APPLE-II *
;* MINI-ASSEMBLER *
;* COPYRIGHT 1977 BY *
;* APPLE COMPUTER INC. *
;* ALL RIGHTS RESERVED *
;* S. WOZNIAK *
;* A. BAUM *
FORMAT = $2E
LENGTH = $2FSo if you can assemble that then you can relocate it anywhere - and have it use your own IO, etc. routines.
- barrym95838
mvk wrote:
[Edit: I'm finding some redundant code and what appears to be ][-specific code in there. It looks like the person transplanting the Apple ][ stuff didn't want to fiddle with the inner mechanism too much, so he patched it together sub-optimally and stopped messing with it as soon as he got it to work. I don't want to bite off more than I can chew, but I'll nibble away at it as time and inspiration permit ...]
I took a first stab at disassembling. First I created an object file for $500-$fff by comparing the other files for their differences. Then I ran it through x65dsasm and edited it until it assembled ok with ca65. I pushed the first result in the Gigatron repo on GitHub:
https://github.com/kervinck/gigatron-ro ... pple-1/asm
It doesn't run on my system yet, because I need additional zero-page relocations.
P.S. I'm interested to find out who's behind apple1notes.com, because that isn't mentioned on the site itself. It could be Wendell Sander.
- barrym95838
There are many hundreds of bytes of dead/useless/corrupt code in there that should be amputated. I am attempting surgery ...
Uncle Warthog
Where I _think_ it might be is on a tape that Apple used to sell for the Apple I, the "Extended Monitor" which I think also may have included the disassembler (though maybe not as they also sold that on tape separately).
Thanks for sharing. I've found more background on these hex files:
https://www.applefritter.com/content/ap ... ed-apple-1
We correctly guessed the site owner
This thread then leads to this disassembly by Jeff Tranter
https://github.com/jefftranter/6502/tre ... %5BMonitor
I'm ashamed to admit I already had this repo cloned months ago, but overlooked this gem because of the Apple][ directory name.
This is the source code for a port of Apple II Monitor to the Apple 1.
- barrym95838
See what I mean about all the stuff that has absolutely no use on the Apple 1? I'm still nibbling at it ...
It seems that it came from a ROM dump with patches on top to bind to Apple-1. It makes sense one would do it that way without better tools. There's quite a bit of stuff to be scrubbed indeed. I'm tempted.
I found a similar back port of the Apple II monitor here:
https://www.scullinsteel.com/apple1/#Mo ... sassembler
It loads in $800.$fff, it starts at an unusual address ($f3d) and routines are clearly rearranged. The origins are unclear to me. I spotted the disassembler in there but it is missing the mini-assembler.
- barrym95838
