The reason I'd shelved working on the code was that, even with the grand total of 44KB
Anyhow, as cross-assemblers on modern machines have access to (effectively) unlimited RAM, this is no longer a problem - but who here is (or has) written ROM code for a BBC Micro using a cross assembler, which did you use, and why?
(I'm looking for a simple way of producing an 8KB or 16KB binary image, that can - initially - be loaded into an emulator for testing, before being burnt out to EPROM for more permanent use in a physical machine.)
(And, yes, I can - and will - submit the source code and ROM image to the code repository, especially if people ask me to
--Martin
[1] From the copyright message in the code, 6 years
