HES FORTH for VIC20 available?
Re: HES FORTH for VIC20 available?
Thanks Nyef.
As Datatronic VICFORTH was mentioned below is a link to that one. I've updated the zip with a new version of the MS-DOS screen editor (old one didn't work under DOSBOX for some reason). Also included is a disassembly. There appears to be some free space in the ROM image potentially allowing a bug-fix for the U* U/ functions which plagued this and other early 6502 Fig-forth implementations.
http://s000.tinyupload.com/index.php?fi ... 5148614814
I just searched for "VIC-20 HES" on eBay and saw a listing for $10 or so that had a bunch of carts. In the lot, was a red labeled HES Forth cart. Might be worth bidding on.
I clean mine with single malt Scotch while I'm drinking Isopropyl alcohol.
Oh crap...I think I've been doing that backwards!
Best place to ask would be over at the Denial forums. If you want to send the file to me, I will start a topic over there and ask where to archive it. I don't think there were many Forth's made for the VIC-20 so it would be nice to have.
Thanks for doing that!
commodorejohn wrote:
...you cleaned your keyboard with an India pale ale?
nyef wrote:
I have no problem with sending the file to some person or organization that will deal with it appropriately, I have no idea who or what that might be.
A zip containing HES VICFORTH dump, manual scan and disassembly is here:
http://s000.tinyupload.com/index.php?fi ... 1945757767
Thanks to everyone involved!
When I try to decompress it, it says not an archive.
How was it packaged up?
- barrym95838
It seems to download and extract just fine on my beat-up old Windoze Vi$ta machine.
Well, it's probably because I can't visit that download site from where I'm at. So I did it on my phone and sent the file over to DropBox. Then copied from DropBox to my PC. So I guess it got messed up in the translations.
I will try again later when I'm on a real computer.
I use 7zip which works with RAR files. I think the problem was my phone. When I am at home later, on my real computer, I will download it then.
FYI, I uploaded the ROM here:
http://sleepingelephant.com/ipw-web/bul ... f=2&t=9484
I also tested it in Vice. Seemed to work but my Forth skills are very rusty.
I encountered an issue that puzzling. After loading a screen previously saved to a file (cassette or disk) it would be followed
by a string of junk graphic characters and an error msg. I managed to avoid the spurious junk and error msg by executing
the following after booting up HES VICFORTH:
FIRST LIMIT OVER - ERASE
This zeroes the disk buffers in RAM including the important 4 extra bytes that follow each buffer. Those 4 bytes not being
zero is what caused the junk/error message.
What's puzzling is that I should need to this at all. I'm using VICE. Maybe a real VIC with HES cartridge works differently?
1 EDIT WIPE
will initialize the buffer after which the LOADS command can be used to retrieve the screen from the file without the
junk & error message.
FYI,
You can find the manual here:
https://archive.org/details/VIC_Forth_1982_HES
Along with the binary I uploaded here:
https://archive.org/details/hes-vic-forth
edx wrote:
An ascii text OCR of the manual will be available shortly. I need to clean up a few errors.
originally provided and can be obtained separately in any case).
http://s000.tinyupload.com/index.php?fi ... 9800039123
edx wrote:
1 EDIT WIPE
screen that you want interpreted. ;S immediately stops forth from interpreting the remainder
of the screen - thereby avoiding the problematic trailing null bytes.
