Hey all! I’ve just gotten my parts, but now I’m in more of a doozy, I have check Garth’s primer as everyone suggests to, and the clock circuit needs a 68pf capacitor and a 5.6k resistor, but with the limited budget and me forgetting to get it, I don’t have it, I have a 1mhz 4 pin crystal oscillator but it just won’t output clock for the w65c02s and I was told that the CPU can take that. I have also seen Ben Eater’s video and saw his wiring.
The resistors that I have only go up to 3k and my capacitors say 22 and 104. If the primer was asking for electrolytic capacitors, are only 100uf and 10uf is there anything I could do to remedy this situation, I do have things I could take parts out of but I wouldn’t count on it...
Clock circuit issues
DerpymanMT
I and my Daisy Bell
- GARTHWILSON
- Forum Moderator
Re: Clock circuit issues
DerpymanMT
Ok I think I got it and just to be sure I had hooked up some leds to the cpu and voila! It is just flickering pretty fast btw is it supposed to be that fast because in Eaters video it was pretty slow, or was that just because of his clock speed settings? Anyways I really need to read the whole thing before asking, but that is what this forum is for asking for help!
I added the LEDs to the address pins and it is just flickering on and off really fast!
Sorry for bothering ya!
-EAS
-EAS
I and my Daisy Bell
With a 1MHz clock, the 6502 will execute 500,000 NOPs per second, iterating through the 64KB address space 7.6 times a second. So yes, you should see the A15 line flash very quickly but regularly.
