Two points:
1.
Read the actual write up about "RTS", the CPU does not actually "remember" the flow of the program as if it is a sentient being, it just follows the flow of the instruction execution.
Technically speaking yes "RTS" is used to return from a subroutine call.. but it's all a matter of perspective......
....and here is the but...
The "RTS" instruction does this by pulling data from the stack....., so you can actually use "RTS" (and other return instructions RTI )to do all sorts of code subversion, by manipulating the contents of the stack or indeed the stack pointer & other registers...
2.
What you are thinking about, is using branches to get to a section of code terminated by an "RTS", in this case, the RTS would return you to whatever address was on your stack.....
so if you have not prepared the stack content beforehand by using a "JSR" well.... who knows where you might end up....
so lets take an example
JSR program_entry.
Return2:
program entry :
Lda #00
Ldx #01
JSR mysub
return1:
dex
beq mysub
lda #02
rts
mysub:
lda #01
rts
The first call using the "JSR" in the code "program_entry", will return back to label "return1:" at completion of the subroutine
However, the "branch" to the subroutine would execute the subroutine code, BUT then it would return BACK to Return2:
and the value #02 would NEVER be put into the Accumulator register...(also making reading the code confusing)
Now this perfectly valid code, but jumping out of functions like this is fraught with all sorts of problems...., not least of which, if changes are made to the function "mysub"
Then potentially it could have all-sorts of consequences...
Since from the program perspective the function " mysub" is only a function if called via a JSR, but becomes NOT a pure subroutine if branched to or jumped to.
Ideally code should "flow" so that it branches as little as possible(fall through), branches add delay & possible confusion.
