It is currently Tue Jun 04, 2024 12:09 am
PostPosted: Tue Oct 01, 2019 7:27 am
I am building my own 6502 based microcomputer. I am going tu put EhBasic on its EPROM.
At this point everything works. Of course I still need add load/save subroutines and as my assembly programming skill grew, I will try to add additional features (like additional commands for RTC usage).
At this point I'd like to set fixed memory size, to do not have to set it after reset. How could it be done?
My memory map:
32kB of RAM
8kB window for four RAM memory banks.
8kB memory space for I/O
16kB of EPROM
What memory size should I set? Full 32kB? 32kB minus zero page and stack?
PostPosted: Tue Oct 01, 2019 8:35 am
My memory map:
32kB of RAM
16kB of EPROM
ehBasic traditionally probes RAM to find the top, but if you are using a 65C02 (WDC), then it's very worthwhile looking at the variant put together by floobydust here: viewtopic.php?f=5&t=5760
There are 2 simple variables to set for Ram_base and Ram_top - so in my 65C02 system, I set Base to $0E00 and Top to $8000 to fit into a 32K RAM, with the ehbasic code assembled to start at $8000, so you can adjust to suit.
PostPosted: Tue Oct 01, 2019 5:15 pm
Ok, now I see that if I simply press an enter without supplying value, it simply assume default value.
If there is a way to permanently disable this question?
PostPosted: Tue Oct 01, 2019 5:34 pm
You have the source ... make the edit.
PostPosted: Wed Oct 02, 2019 12:39 am
If you grab my version referenced above, there’s no prompt to worry about. Just set your base and top addresses and you’re done. Also, latest version has an improved RAM test plus Load and Save vectors with some useful code... just implement Xmodem for transfer and you’re done.
PostPosted: Fri Oct 04, 2019 6:22 am
I have to admit that I am a little bit confused... This version is a little bit different from standard 2.22, which I used in my project.
1) There is no min_mon.asm file, so where to look for low level I/O subroutines? I thought they were transferred to the main basic.asm file, but there are no ACIAout and ACIAin subroutines. Were they renamed?
2) I see it doesn't assemble with acme asembler...
Maybe you could simply point me to the fragments of code responsible for skipping memory size prompt and Xmodem load/save functions? This way I could include them into my own project...
PostPosted: Fri Oct 04, 2019 1:49 pm
So, here's some detail:
1- I use the WDC Assembler/Linker package, so the source has been reformatted and much cleaned up. Note that the WDC Tools are free.
2- It's now a single source file, there is NO minimal monitor code, it relies on your SBC having a BIOS for your hardware that provides at least two basic functions:
a- Get a character
b- Send a character
3- All of the vectors are soft-loaded into Page 4 ($0400) as is the input buffer. In the source file, these vectors are declared starting at line 7523. The BIOS routines (from my SBC) are shown starting at line 7548, i.e., $FF36 is get a keystroke, $FF3C is send a character to the console.
4- Memory test, show and go starts at line 527. It's fairly simple, loads/tests for $55, $AA and $00 starting at Ram_base to Ram_top.
5- Xmodem code pieces still rely on my C02 Monitor for the core Xmodem-CRC transfer. The code in the basic source file handles specifics for EhBasic, then call the monitor routines. The Xmodem code in the basic source starts at line 7514.
6- Cold and Warm start are handled by the Monitor... which simply prompts the used for Cold or Warm, then Jumps to the Basic code. Cold start is at $B000, which is start of the code assembly. Warm start is $0000, which requires that basic was Cold started earlier, else you just jump to whatever is loaded at $0000.
My updated code has all of Klaus' fixes and numerous enhancements along with a consolidated page zero usage, plus it requires less page zero use as the Chrget/Chrgot equivalent code (LAB_IGBY) is maintained in ROM and only the 2-byte pointer is maintained in page zero.
If you can provide some details for your SBC hardware, perhaps I can provide you a simple BIOS that will work. My current C02 Pocket SBC uses an older Philips/NXP SCC2691 UART and one of my older SBCs uses a common 6551 ACIA. I have full-duplex interrupt-driven and buffered BIOS code to run either chip as a console.
I'll be posting an updated BIOS/Monitor for my current C02 Pocket SBC shortly. The BIOS (and hardware page) take less than 1KB and the Monitor just a tad less than 5KB and is quite rich in function. It also requires the WDC Tools package to assemble and link.
Hope this helps....
PostPosted: Sun Oct 06, 2019 12:37 am
I maintain a parallel fork of EhBasic where almost everything that is specific to a particular target is stripped out and placed in a separate monXXX.asm file, so to target a different platform you can leave the Basic interpreter code untouched and simply write a new monXXX.asm file. I've just updated it with the latest v2.22p4 updates.
For the OP's original question, copy one of the monXXX.asm files and update it. From what you posted I'm guessing:
$0000-$7FFF 32kB of RAM, $00xx=zero page, $01xx=stack, $0200 upwards: fully free
$8000-$9FFF 8kB window for four RAM memory banks.
$A000-$BFFF 8kB memory space for I/O
$C000-$FFFF 16kB of EPROM
So:
.define    TARGET   your_target_name
BREAK    =$1B   ; Code of keypress to interrupt program
MEMBOT   =$0300 ; Bottom of memory to test for presence of RAM
MEMTOP   =$8000 ; Top of memory to test for presence of RAM
ZPSTART  =$00   ; Start of zero page workspace
ZPEND    =$8F   ; End of zero page workspace
ZPROUT   =0     ; No subroutines in zero page
WSSTART  =$0200 ; You need one page of fixed workspace
CODESTART=$C000 ; Is this where your ROM is?
Then update MON_INIT for any target-specific initialisation you need to do, and write routines for your target to do Check for keypress, Character output, program load, and program save.
If you want the system to supply the memory size instead of asking the user, use:
MEMBOT   =$0    ; Ask monitor for bottom of memory
MEMTOP   =$0    ; Ask monitor for top of memory
and have a routine in the monXXX.asm file MON_LIMITS that sets the memory size, eg:
MON_LIMITS
LDY   #$80   ; Top of memory at $8000
LDX   #$00
STX   Ememl  ; set end of mem low byte
STY   Ememh  ; set end of mem high byte
STX   Sstorl ; set bottom of string space low byte
STY   Sstorh ; set bottom of string space high byte
LDY   #$03   ; Bottom of memory at $0300
LDX   #$00
STX   Smeml  ; save start of mem low byte
STY   Smemh  ; save start of mem high byte
RTS
JGH - http://mdfs.net
