http://6502org.wikidot.com
(Hope you don't mind me calling it the 6502.org Wiki, Mike!) I've put up a few pages as a starting point. The wiki is set up so that anyone can view pages, but you must be a member of the wiki to make edits. The reason for this is NOT to prove that you're some sort of super duper 6502 expert, it's to prevent people from vandalizing or posting spam on the wiki. You can become a member by being invited by a wiki administrator, which at the moment is only one person, namely me. Here is how I propose we proceed.
There are two ways an invitation can be extended. If you already have a wikidot account (Wikidot accounts are free) an invitation can be extended that way. (Some wikidot wikis are set up so that anyone with a wikidot account can edit it. Our wiki imposes the additional requirement that you also be a member of our wiki.) The other way is to extend an invitation by e-mail.
It would probably be wise to have at least a few people with admin privileges so that if someone is out of town, or sick, or gets eaten by a lion, etc. and something comes up that requires admin privileges, then there will be someone else available. For the time being, inviting/approving new members would probably the most common task that requires admin privileges. Maybe something else will come up that requires admin privilege, I really don't know. We'll cross that bridge when we come to it.
Also, since I may get inundated with member requests, before extending invitations to everyone, it would probably make sense to start with just one person, then get that person set up first as member, then with admin privileges. In other words, a guinea pig. This will give me a chance to learn how to add members, before opening the floodgates.
As far as I am concerned, everyone from the forum is welcome to become a wiki member also. So, here is what to do to become a member. Send me PM via the forum. (I know some people e-mail addresses, but in the interests of consistency, send me PM instead.) If I don't recognize your username, I can easily and quickly look up your posts (even if there's only a couple of them) to make sure you're an actual 6502 enthusiast, and not someone who signed up for a forum account to just spam the forum. Since I will be reading each PM individually it doesn't have to be anything special. Here are a couple of examples.
Example #1:
Subject: wiki
Body:
my e-mail is lmao@notredamesseason.com
I wanna be an admin
I'll be the guinea pig
Example #2:
Subject: wiki
Body:
my wikidot username is johnsmith123
Then I will choose a guinea pig and reply ONLY to that person. Once the guinea pig is up and running, I'll get everyone else set up. Then I will post another message in this thread to let you all know that I have done that. THEN you can hassle me about why it isn't working.
Whew! Are we almost done? No.
We should discuss how we want to handle new members in the future. Just on general principles, I'm opposed to having to sign up for A to get access to B, where in this case, A is the forum and B is the wiki. In practice, this probably won't be an issue, since who going to want to be a member of the wiki, but not the forum? However, one alternative is that it's possible to set up a page on the wiki where someone can fill out form to apply to be a member. They'd be instructed to submit some sort of technical content (e.g. changes or additions they'd make). Maybe something along the lines of "here's an addressing decoding article" or "you can optimized the code on page such-and-such by doing this". Anyway, we don't have to make a decision now, but it's food for thought.
Since we already have an established community here, we can probably just play it by ear, for the most part. There are only a few rules that come to mind.
1. Like 6502.org and its forum, the content should be targeted towards general 6502
2. There are no limits are the number of pages, but the total amount of space for file attachments (like pictures) is 100 MB. So please don't upload .pdfs (e.g. datasheets, scanned manuals, etc.) or .zip files since we'll run out attachment space quickly. Notice how I did it on the 65816 datasheet errata page; I didn't upload the datasheet onto the wiki, the datasheet is stored at WDC's website and I just linked to it. Likewise for the FIG-Forth errata page; in that case, the zip file is store here at 6502.org and the wiki page simply has a link to it. It is okay to upload a diagram or a schematic (e.g. a .png or .svg file) when it's relevant to the wiki article. For example, if you write an article about address decoding using only an 'HC00, an accompanying (black and white) schematic (e.g. a .png file) is clearly relevant to the article and should only be a few dozen kilobytes or so.
3. Since we already have a forum, to me it would make sense for the wiki to be article-oriented (like Wikipedia or the Sports Argument Wiki) rather than lots of discussion amidst the article itself (like WikiWikiWeb). When discussion is needed, a new thread can be started here in the forum and then linked to from the wiki.
What else...there's a page at wikidot describing the wiki syntax. Plus there's a how-to guide. It seems pretty easy to use. It's similar to the quote/code/bold tags here in the forum. A couple of things I've encountered so far.
1. The code block tags don't indent the first line of source code. Notice that the first line of code on the FIG-Forth errata page starts with a semicolon. If the line with the semicolon is removed, then the new first line won't be indented. I should probably submit some sort of bug report or a change request about this, but the semicolon work-around is what I came up with and it's easy to do.
2. There are no concept of directories at wikidot (there's categories which isn't quite the same thing). In the pages I've put up so far,I've adopted the naming convention:
directory-subdirectory-subsubdirectory-article
as a way of faking subdirectories. So errata is the errata page errata-software is the software errata page, and errata-software-figforth is the FIG-Forth errata page. And so on.
Anyway, it would probably be good to keep a copy of anything you add to the wiki in case something goes wrong, or at least until we all get a better idea of how it should be organized.
Finally, one other thing we should probably discuss at some point is the license for the wiki content. Right now its a Creative Commons license (the default license), but we can use whatever license we want, there's even an "other" option where you can write your own license.
If you have questions or comments, fire away. I'll answer what I can. I'm learning too.
