A simple 6502 computer (doesn't work though)
Re: A simple 6502 computer (doesn't work though)
LIV2 wrote:
Should the A14 input of the SRAM be connected to A14 instead of GND so that writes to IO space don't write to the lower half of the RAM?
Except that with the RAM's A14 tied low instead of connected to A14 any writes between $4000-$7FFF write to $0000-3FFF don't they? I thought the idea was to have the writes go through to the ram's $4000-7FFF half where it can not be read back and thus won't interfere with I/O etc
I agree with LIV2:-
With the RAM A14 tied low, this reduces the available RAM by half. So the 32K byte chip is now effectively a 16K byte chip.
The RAM chip’s /CE pin is only driven active low when the PHI2 signal is high and A15 is low. This maps all access to 0x0000 to 0x7FFF, a 32K byte range.
With CPU A14 connected to the RAM /OE pin, this means that when the CPU address bus has A14 low, RAM addresses 0x0000 to 0x3FFF can be read by the CPU (a 16K byte range).
When the CPU address bus has A14 low or high, the CPU can write to the RAM, (addresses 0x0000 to 0x7FFF) but writes in the 0x4000 to 0x7FFF range will actually write to RAM addresses in the 0x0000 to 0x3FFF range.
If instead the RAM chips A14 line is connected to the CPU’s A14 line, then any writes to 0x4000 to 0x7FFF range will write to RAM addresses in the 0x4000 to 0x7FFF range and the 0x0000 to 0x3FFF area will not be overwritten. The CPU will be unable to read data back that is written in the 0x4000 to 0x7FFF range, but that does not matter if you only want 16K bytes of RAM.
Mark
Mark
- barrym95838
(I'm not a hardware guy, but I always get a smile out of discussions involving Write-Only Memory, especially since my own biological memory seems to be slowly converting to the same, one addressable unit at a time)
- Oneironaut
Did you know that a standard 7404 inverter also works as a 4 megabyte Serial Write Only RAM?
You send a clock to pin 1 and pulse data into pin 3.
Really, it is true.
Prove me wrong!
Brad
Really, it is true.
Prove me wrong!
Brad
PS- Brad, are you sure it's 4 megabyte?
I'm not sure if it's the cause of this though as the only memory usage in the example code is the stack but I/O writes are effectively going to $0000 so there must be something else
I think barrym95838 was on to something when he suggested inlining the delay, there could be some other problem writing/reading ram that is screwing up the return address.
barrym95838 wrote:
This might be a silly notion, but are you certain that you're always getting a clean rts from your jsr delay? Would it be helpful to try a version that in-lines the delay?
; 64tass Turbo Assembler Macro V1.52.1237? listing file
; 64tass -Demulator=false -o via.bin --nostart --no-monitor --line-numbers --tab-size=1 --list=via.lst via.asm
; Sun Jun 30 06:49:08 2019
;Line ;Offset ;Hex ;Source
;****** Command line definitions
=false emulator=false
:1 ;****** Processing input file: via.asm
5 =$6000 via1base = $6000
7 =24576 via1rb = via1base+0 ; write output register b, read input register b
8 =24578 via1ddrb = via1base+2 ; data direction register b
10 .8000 nmi:
11 .8000 irq:
12 .8000 coldstart:
13 .8000 a2 ff ldx #$ff
14 .8002 9a txs ;Initialise stack register
15 .8003 8e 02 60 stx via1ddrb ; set all PB pins to be outputs
16 .8006 loop:
17 .8006 9c 00 60 stz via1rb
18 .8009 a2 ff ldx #$ff
19 .800b loop2:
20 .800b a0 ff ldy #$ff
21 .800d loop3:
22 .800d 88 dey
23 .800e d0 fd bne loop3
24 .8010 ca dex
25 .8011 d0 f8 bne loop2 ; wait for a while
26 .8013 ce 00 60 dec via1rb
27 .8016 a2 ff ldx #$ff
28 .8018 loop4:
29 .8018 a0 ff ldy #$ff
30 .801a loop5:
31 .801a 88 dey
32 .801b d0 fb bne loop4
33 .801d ca dex
34 .801e d0 fa bne loop5
35 .8020 80 e4 bra loop
38 .8022 delay:
51 >fffa 00 80 .word nmi ;NMI
52 >fffc 00 80 .word coldstart ;RESET
53 >fffe 00 80 .word irq ;IRQ
;****** End of listing
It looks like you've mis-nested loop4 and loop5. That would probably influence the results by throwing the CPU into an infinite loop.
Another thing to try, once you've fixed that and tried it, is to delete the LDX/Y #$FF instructions entirely. The tiiming loops should work fine without them, since the index registers are not otherwise used.
So this program works:
; Tue Jul 2 19:16:44 2019
10 .8000 nmi:
11 .8000 irq:
12 .8000 coldstart:
16 .8006 loop:
18 .8006 a9 55 lda #$55
19 .8008 8d 00 60 sta via1rb
20 .800b a2 ff ldx #$ff
21 .800d loop2:
22 .800d a0 ff ldy #$ff
23 .800f loop3:
24 .800f 88 dey
25 .8010 d0 fd bne loop3
26 .8012 ca dex
27 .8013 d0 f8 bne loop2 ; wait for a while
29 .8015 a9 aa lda #$aa
30 .8017 8d 00 60 sta via1rb
31 .801a a2 ff ldx #$ff
32 .801c loop4:
33 .801c a0 ff ldy #$ff
34 .801e loop5:
35 .801e 88 dey
36 .801f d0 fd bne loop5
37 .8021 ca dex
38 .8022 d0 f8 bne loop4
39 .8024 80 e0 bra loop
42 .8026 delay:
55 >fffa 00 80 .word nmi ;NMI
56 >fffc 00 80 .word coldstart ;RESET
57 >fffe 00 80 .word irq ;IRQ
; Tue Jul 2 19:21:25 2019
10 .8000 nmi:
11 .8000 irq:
12 .8000 coldstart:
13 .8000 a0 ff ldy #$ff
14 .8002 a2 ff ldx #$ff
15 .8004 9a txs ;Initialise stack register
16 .8005 8e 02 60 stx via1ddrb ; set all PB pins to be outputs
17 .8008 loop:
19 .8008 a9 55 lda #$55
20 .800a 8d 00 60 sta via1rb
21 .800d loop2:
22 .800d loop3:
23 .800d 88 dey
24 .800e d0 fd bne loop3
25 .8010 ca dex
26 .8011 d0 fa bne loop2 ; wait for a while
28 .8013 a9 aa lda #$aa
29 .8015 8d 00 60 sta via1rb
30 .8018 loop4:
31 .8018 loop5:
32 .8018 88 dey
33 .8019 d0 fd bne loop5
34 .801b ca dex
35 .801c d0 fa bne loop4
36 .801e 80 e8 bra loop
39 .8020 delay:
52 >fffa 00 80 .word nmi ;NMI
53 >fffc 00 80 .word coldstart ;RESET
54 >fffe 00 80 .word irq ;IRQ
So next thing to try is to put the delay loop in a subroutine to check if the RAM works as it should.
This code does not work so something how I connected the RAM is wrong.
BTW, the result is the same whether A14 is grounded or connected to CPU's A14, VIA's port gets stuck.
; Tue Jul 2 19:31:12 2019
10 .8000 nmi:
11 .8000 irq:
12 .8000 coldstart:
14 .8000 a2 ff ldx #$ff
15 .8002 9a txs ;Initialise stack register
16 .8003 8e 02 60 stx via1ddrb ; set all PB pins to be outputs
17 .8006 loop:
19 .8006 a9 55 lda #$55
20 .8008 8d 00 60 sta via1rb
28 .800b 20 18 80 jsr delay
29 .800e a9 aa lda #$aa
30 .8010 8d 00 60 sta via1rb
37 .8013 20 18 80 jsr delay
38 .8016 80 ee bra loop
41 .8018 delay:
42 .8018 a2 ff ldx #$ff
43 .801a loop2:
44 .801a a0 ff ldy #$ff
45 .801c loop3:
46 .801c 88 dey
47 .801d d0 fd bne loop3
48 .801f ca dex
49 .8020 d0 f8 bne loop2
50 .8022 60 rts
54 >fffa 00 80 .word nmi ;NMI
55 >fffc 00 80 .word coldstart ;RESET
56 >fffe 00 80 .word irq ;IRQ
Maybe write a simple RAM testing routine that doesn't use the stack. Walking bit inversions, self-addressing, that sort of thing.
- barrym95838
Do you have a spare SRAM you can swap in? Or maybe try initializing your stack pointer to something like #$EE instead of #$FF?
Clearly the correct operation of zero-page and the stack page is the most critical. Without them, a significant proportion of 6502 opcodes become useless. But I think we can now assume that the VIA and ROM are working correctly.
So here's an attempt to verify pages 0-3 (the first kilobyte) without relying on correct RAM functionality, and using the VIA for status output: I've edited it to ensure that none of the branches should be out of range, and to make the output sequence slow enough to read.
coldstart:
LDX #$FF
STX via1ddrb
STZ via1rb ; output $00 -> filling zeroes
INX
fillzero:
STZ $00,X
STZ $100,X
STZ $200,X
STZ $300,X
INX
BNE fillzero
INC via1rb ; output $01 -> checking zeroes
checkzero:
LDA $00,X
BNE error0
LDA $100,X
BNE error1
LDA $200,X
BNE error2
LDA $300,X
BNE error3
INX
BNE checkzero
INC via1rb ; output $02 -> filling ones
DEC A
fillones:
STA $00,X
STA $100,X
STA $200,X
STA $300,X
INX
BNE fillones
INC via1rb ; output $03 -> checking ones
checkones:
CMP $00,X
BNE error0
CMP $100,X
BNE error1
CMP $200,X
BNE error2
CMP $300,X
BNE error3
INX
BNE checkones
INC via1rb ; output $04 -> filling self-address
BRA filladdr
; Error routines in the middle so they can be reached from both ends
error0:
LDY #$00
TXS
BRA errorloop
error1:
LDY #$10
TXS
BRA errorloop
error2:
LDY #$20
TXS
BRA errorloop
error3:
LDY #$30
TXS
errorloop: ; rapidly cycle through indication of test stage, error page (moved to high nybble), error index within page
INX
BNE errorloop
INC A
BNE errorloop
TSX
TXA
LDX via1rb
STY via1rb
TAY
TXS
LDA #0
BRA errorloop
filladdr:
TXA
STA $00,X
STA $100,X
STA $200,X
STA $300,X
INX
BNE filladdr
INC via1rb ; output $05 -> checking self-address
checkaddr:
TXA
CMP $00,X
BNE error0
CMP $100,X
BNE error1
CMP $200,X
BNE error2
CMP $300,X
BNE error3
INX
BNE checkaddr
INC via1rb ; output $06 -> filling self-page
fillpage:
STZ $00,X
LDA #1
STA $100,X
LDA #2
STA $200,X
LDA #3
STA $300,X
INX
BNE fillpage
INC via1rb ; output $07 -> checking self-page
checkpage:
LDA $00,X
BNE error0
INC A
CMP $100,X
BNE error1
INC A
CMP $200,X
BNE error2
INC A
CMP $300,X
BNE error3
INX
BNE checkpage
INC via1rb ; output $08 -> test complete
done:
WAI
BRA done
