Somewhere you need to set the DB back to input mode...
I do, setting the DB in input mode is the first line of my ISR routine
How do your timings compare to what's in the data sheet?
Unfortunately I don't know. The Teensy 3.6 is a fast micro controller and I have no solution to know how to achieve nano seconds delays.
I asked on the Teensy forums, how many NOPs could achieve, let say, 10ns wait but the only answer I got was "You need to check with a good oscilloscope", which is a tool I don't own.
But, I've found many many articles on the web about interfacing an Arduino or even a Teensy with 6505,65C05,6509 - And they achieved good results without being tight on timings at all, and sometimes very basic code.
My best guess is that I'm doing something wrong.
But just to know : are there a lot of counterfait or broken 6502 on the market ? I bought the 6502 and G65SC02 from the same reseller, a quite old electronic shop (a real one) around 7/9 €
What are the chances to have a deffective cpu ?
