It is currently Fri Nov 22, 2024 6:30 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Wed May 29, 2019 3:05 pm
Thanks for your helpful participation, Ed.
FWIW, Applesoft "agrees" more or less with your Version 4r32 result:
]LIST
10 E = 0
20  FOR I = 15 TO 17 STEP 2
30  FOR J = 1 TO I
40 A = J / I
50 F = A * A / A - A
60 E = E +  ABS (F)
70  NEXT
80  NEXT
90  PRINT E
]RUN
1.26601663E-09
]PR#0
PostPosted: Wed May 29, 2019 4:00 pm
I've been looking at this thread with interest as I have a need for a single-precision FP format, preferably IEEE 754 to interface with a system where I have some libraries that use that format, but not any actual low-level code like add, multiply and so on ...
I got some slightly surprising results from this test program, which does some divisions and multiplications and sums up the absolute errors:
   10 E=0
   30 FOR J=1 TO I
   40 A=J/I
   50 F=A*A/A-A
   60 E=E+ABS(F)
   70 NEXT
   80 NEXT
   90 PRINT E
The oddity is that an older version of Acorn's BBC Basic gets a smaller result, and therefore seems to be more accurate than the newer:
1982 version 2     8.14907253E-10
1988 version 4r32  1.26601662E-9
I was curious about this as I want to use 32-bit IEEE 754 for a project (rather than Woz, etc. FP) so gave it a go on an ATmega which uses that format (or is supposed to) and it yielded
1.04308e-07
Just to compare, in double precision IEEE 754 using my desktop i3:
3.05311e-16
I can reproduce
1.26601662E-9
with BBC Basic 4, and
8.14907253E-10
using older BBC Basics.
Really no surprise that the 5-byte format that BBC Basic uses shows more precision than the 4-byre IEEE format I guess.
ehBasic (4-byte floats) yields:
1.04308E-07
and Applesoft (5-byte floats AIUI):
1.26601663E-09
Interesting observations here: ebHasic and IEEE 754 appear to be the same although I've just dome some superficial checks - and it appears that while Microsofts format (MBF) is similar in terms of bits used (1+8+23), the binary representation is different and IEEE 754 calls for more bits to be used when performing intermediate calculations. MBF preceded IEEE 754 and for 8-bit computers was probably good enough at the time. MSs 5-byte format wasn't generally used on the 6502 as they ran out of code space in typical 8K ROMs at the time - Applesoft having a 12K ROM being a notable exception. (What I've gained from wikipedia and a few other sites this afternoon)
However, Applesoft 5-byte format is virtually identical to BBC Basics 5-byte format in terms of precision with this trivial test (might actually be identical, masked by rounding in printing - I'd need to look at the actual binary values to check)
So - for me, I'm still after a native 6502 implementation of IEEE 754 for single precision numbers, but the above has been an interesting little investigation.
PostPosted: Wed May 29, 2019 4:14 pm
Oh, that's quite interesting in itself - I think Applesoft has rounded up incorrectly. I think the number we are printing must be
> PRINT 1392/1024/1024/1024/1024
1.26601662E-9
which is exactly
.000000001266016624867916107177734375
and so shouldn't be printed as
1.26601663E-9
(One thing about IEEE and Acorn's floating point format is that they get one extra bit for free, because the mantissa, unless zero, would always be normalised to have a leading 1, which therefore need not be stored. I'm not sure about other Basics.)
I think I may have found the difference in 4r32: when A=1/17 (or 2/17, 4/17, 8/17 or 16/17) then although A*A is computed identically, A*A/A comes out different by 2^-36. Probably one unit in the last place, at a guess. (Edit: confirmed. Mantissa of 1/17 is 70F0F0F1 in hex - it's a repeating number and the missing F rounds up to 1 - and the mantissa of the inaccurate result is coming out as 70F0F0F2.)
PostPosted: Wed May 29, 2019 10:44 pm
Thanks for your research efforts, drogon. Microsoft's 40-bit floats were more prevalent than you imply, though, at least in raw population numbers. I'm relatively certain that Commodore had been using them in all of their 8-bit machines (VIC-20, C=64, etc.), all the way back to the first PETs in 1977. And they sold millions of those little machines!
PostPosted: Thu May 30, 2019 5:20 am
SANE (Standard Apple Numerics Enviroment) uses IEEE 754; there is a 6502 implementation. It's also in the Apple IIgs Toolbox, but the implementation (the one in ROM, anyway) just switches to 8-bit mode and executes the 6502 code, if memory serves.
Apple Assembly Line published a series of articles implementing a 18 digit BCD floating library (DP18), starting in the May 1984 issue. They also sold a 21 digit binary floating point libary called DPFP.
http://www.txbobsc.com/aal/index.html
The floating point format used by KIM Focal is the same as the Rankin/Woz format (by coincidence, I suspect).
There's also this discussion of the Rankin/Woz routines from 15 years ago:
viewtopic.php?f=2&t=495
PostPosted: Thu May 30, 2019 3:27 pm
When you think about it, this makes complete sense. I don't think 8-bit 6502 code on an '816 is at any particular disadvantage in this case. The system is probably dominated by 8-bit data motion beyond any potential benefit you might get from using 16b ADC and SBC.
PostPosted: Thu May 30, 2019 3:52 pm
Thanks for that!
PostPosted: Fri May 31, 2019 8:42 pm
Hmm, I think I might have learnt something - see the thread over on stardot where I look at little further at Basic 4 vs Basic 2:
https://stardot.org.uk/forums/viewtopic ... 20#p238620
The bottom line is that my efforts to make a figure of merit by computing A*A/A-A might well be misguided: a non-zero answer for various values of A could be correct, for correctly-rounded finite-precision computation.
That said, I might still be missing something.
PostPosted: Sat Jun 01, 2019 4:56 pm
True, but generally smaller errors are still better. Correct rounding minimises error at each step.
PostPosted: Sat Jun 01, 2019 6:55 pm
Careful with that - double rounding can introduce error. There's a particular case where it's beneficial to round to odd, where the normal choice is to round to even. I can't find the article I read about this, but here's a similar one:
https://www.exploringbinary.com/double- ... nversions/
PostPosted: Wed Jun 05, 2019 7:26 pm
Here's the Woz normalizer in the Apple ][ ROM:
F455: A5 F9     NORM1     LDA  M1       HIGH-ORDER MANT1 BYTE.
F457: C9 C0               CMP  #$C0     UPPER TWO BITS UNEQUAL?
F459: 30 0C               BMI  RTS1     YES, RETURN WITH MANT1 NORMALIZED
F45B: C6 F8               DEC  X1       DECREMENT EXP1.
F45D: 06 FB               ASL  M1+2
F45F: 26 FA               ROL  M1+1     SHIFT MANT1 (3 BYTES) LEFT.
F461: 26 F9               ROL  M1
F463: A5 F8     NORM      LDA  X1       EXP1 ZERO?
F465: D0 EE               BNE  NORM1    NO, CONTINUE NORMALIZING.
F467: 60        RTS1      RTS           RETURN.
That CMP #$C0; BMI RTS1 is a pretty neat hack! I made my updated version even faster [Edit: at least faster for two or more shifts] by keeping M1 in A and X1 in Y for the loop, and I made it so X can point to either accumulator to minimize the need for SWAP:
norma:
      ldx   #fpa        ; point to fpa.
normx:
      ldy   0,x         ; expx
      beq   normzz      ;
      lda   1,x         ; high-order mantx byte.
norm2:
      cmp   #$c0        ; upper two bits equal? (neat!)
      bmi   normz       ; no: done.
      asl   3,x         ; yes:
      rol   2,x         ;   left shift mantx and
      rol               ;
      dey               ;   decrement exp.
      bne   norm2       ; if exp > 2^-128 then loop.
normz:
      sta   1,x         ; store high-order mantx byte.
      sty   0,x         ; store expx and return.
normzz:
      rts               ;
