6502 ALU pseudocode
ProfJ
6502 ALU pseudocode
Post by ProfJ »
Hi Folks,
This is my first post on this forum, hope it's in the right place!
I'm trying to write some pseudocode for the 6502 ALU operation. It seems to be straightforward, except for the BCD addition when DAA is high. This is what I have (the variable names come from the block diagram, and I/ADDC is a name, not a division operation). Apologies, this message editor kills my indenting:
if SUM == 1
if DAA==0
[ACR ADD] = AI + BI + I/ADDC
AVR = (AI(7) && BI(7) && ~ADD(7))||(~AI(7) && ~BI(7) && ADD(7))
else
[HC ADD(3:0)] = AI(3:0) + BI(3:0) + I/ADDC
[ACR ADD(7:4)] = AI(7:4) + BI(7:4)
end
end
I'm mainly concerned with how the carry in, and half-carry and carry out work, can anyone tell me if this is correct?
Thanks
Jon
bdk6
Re: 6502 ALU pseudocode
Post by bdk6 »
You may want to explain your selection of names. I don't think are common/standard. The DAA input(?) seems like it may have come from 8080 land. But it may just be me; I'm not an '02 guru. Nevertheless, this page linked to on the front page of 6502.org may be of some help:
http://6502.org/users/dieter/bcd/bcd_0.htm
It's a description of how the 6502 does BCD.
Welcome Jon! It's (very) tricky to get BCD right, so I know I can't say anything about the correctness of your approach even by careful code reading. Personally I'd inspect the code of any existing core (or emulator) which is open source and passes a suitable testsuite. Have you tried Bruce's decimal test? Or Klaus' full testsuite?
Ref: http://visual6502.org/wiki/index.php?ti ... stPrograms
Welcome! To preserve formatting, use the editor's Code style.
    if SUM == 1
        if DAA==0
	   else
	   end
   end
Yes, put your code between the tags [code] and [/code]. (I did something else here to keep them from taking effect.)
ProfJ
Post by ProfJ »
Thanks for that link. The signal names are shown in the standard 6502 block diagram, see for example here http://www.weihenstephan.org/~michaste/ ... 2/6502.jpg .
bdk6
Post by bdk6 »
Yeah, sorry about that. I was preoccupied when I first read your post and only got about half the information. I do think it would be useful to have put a link to that block diagram in the post for morons like me. I realized right after I commented that you mentioned it. I was gonna be quiet and hope nobody noticed :oops:
