Fleet Forth design considerations
- barrym95838
Re: Fleet Forth design considerations
Add a vote for the "comment style" from me as well.
JimBoyd wrote:
In Fleet Forth, I treat some of the CONSTANTs more like VALUEs. I was wondering if it would be worth the overhead in memory to implement VALUEs and redefine IS and (IS) to only work on VALUEs and DEFERed words.
#BUF is a VALUE and TYPE is a DEFERred word.
: IS ( -- )
' DUP @
DUP [ ' #BUF @ ] LITERAL <>
SWAP [ ' TYPE @ ] LITERAL <> AND
ABORT" CAN'T SET"
STATE @
IF COMPILE (IS) , EXIT THEN
>BODY ! ; IMMEDIATE
The hard constants are words such as 2 , 3 , C/L , and B/BUF that should be immutable. They are defined with CONSTANT .
The values are words such as COLS , #BUF , and LIMIT that one can freely change and are defined with VALUE .
The 'soft' constants are words such as MRU and LRU that need changed by one of the Forth words ( in this case CONFIGURE ), but should never be modified any other way. These words are still CONSTANTs in Fleet Forth.
If Fleet Forth were in ROM, I would need a new constant-like word, maybe SEMICONSTANT or SOFTCONSTANT , but they're a bit long.
I've just streamlined DJIFFIES , the word that takes a positive double number and waits that many jiffies ( 1/60th of a second on the Commodore 64 ) . It is also used by JIFFIES , the word that takes an unsigned single number and waits that many jiffies.
DJIFFIES works by keeping the number of jiffies to delay on the stack as well as the latest jiffy clock value. Each time through the loop, it subtracts the difference from the amount of time to wait. The idea came from DOWN-COUNTER on page 130 ( 140 of the PDF ) in the book Real Time Forth by Tim Hendtlass.
When I was testing my multitasker, I noticed that the loop in DJIFFIES runs several times per jiffy. With three background tasks, two using DJIFFIES ( actually JIFFIES ) for a delay and one counting how many times it runs, the entire round robin runs several times a jiffy. I realized that when the difference between the current jiffy clock value and the previous one is subtracted from the amount of time to delay, either 0 or -1 is added to the remaining time. I only needed to use the lower cell of the jiffy clock value. Here is the code:
JIFFIES takes an unsigned number and has a maximum delay of:
18 minutes 12 seconds and 15 jiffies.
DJIFFIES takes a positive double number and has a maximum delay of:
414 days 6 hours 3 minutes 14 seconds and 7 jiffies or
2,147,483,647 jiffies.
SCR# 41
// DJIFFIES
HEX
// TAKES POSITIVE DOUBLE NUMBER
// AND DELAYS THAT MANY JIFFIES
: DJIFFIES ( D+ -- )
JIFFY@ DROP
BEGIN
PAUSE
JIFFY@ DROP DUP>R -
// COMPENSATE FOR RESET AT 24 HOURS
0 MIN
S>D D+ R> OVER 0<
UNTIL
DROP 2DROP ;
SCR# 42
// JIFFIES
HEX
: JIFFIES ( U -- )
0 DJIFFIES ;
Here is a print dump from an interactive session where I performed a rough test on JIFFIES ( and therefore DJIFFIES .) The word TEST 'borrows' PAUSE to increment a counter once each time through the loop and resets it at the end of the test. The BASE is decimal.
So the delay loop, including the code to increment COUNTER runs about 16 times per jiffy or roughly 960 times per second.
OK
VARIABLE COUNTER OK
CODE UPCOUNT OK
COUNTER INC, OK
0= IF, COUNTER 1+ INC, THEN, OK
NEXT JMP, END-CODE OK
SEE UPCOUNT
UPCOUNT
22473 22457 INC ' COUNTER >BODY
22476 22481 BNE
22478 22458 INC ' COUNTER >BODY 1 +
22481 2111 JMP NEXT
OK
: TEST
COUNTER OFF
['] UPCOUNT IS PAUSE
100 JIFFIES
SINGLE ; OK
TEST COUNTER ? 1604 OK
CONSOLE
While developing Fleet Forth, I've been using it as a testbed for Forth ideas. I'm not even sure if testbed is the right word as I have no professional programming experience.
In Fleet Forth, TYPE is a deferred word that is normally set to (TYPE). There is also the printer version, (PTYPE) , and the logger version ( to send output to both the printer and the screen ) , (LTYPE). There is a separate word, DTYPE , which is not deferred and is used to send commands to the disk drive. The only real difference is that the other TYPE words update variables for output formatting and DTYPE does not.
(TYPE) , (PTYPE) , and (LTYPE) all call PAUSE after 'typing' the string. The last two also have to clear the communications channel to the printer when they are done and before pausing. The easiest thing to do was have (TYPE) branch to CLRCHN .This requires a renaming of (TYPE) to <TYPE> and factoring out PAUSE . If I'm branching into another code word, I can't have a transition to high level to call PAUSE . Even if <TYPE> didn't branch to CLRCHN to clear the communications channel, it would still need to be a separate factor for (PTYPE) since (PTYPE) must clear the channel before pausing.
(PTYPE) would be defined as:
But I would have three words for TYPE in the kernel:
TYPE , (TYPE) , and <TYPE> .
QTYPE is similar.
QTYPE or quote type is for printing anything that may contain unprintable characters that could make the display do undesirable things, such as an index for a range of blocks or listing a block that may contain data instead of text.
Since Fleet Forth is an ITC Forth and each reference to a word is only one cell, I tried a slightly different approach. A mixing of a deferred word and a normal colon definition.
And the words which redirect output:
The idea is the first cell is the 'deferred' part followed by code common to all 'vectors' this 'deferred' word is set to execute. I know this isn't portable, but maybe it can be made portable with a new word DEFER: . Each system to use this idea would have to define their own version of DEFER: because it is system dependent. In Fleet Forth it would be something like this:
I haven't tried this yet because I'm away from my desktop ( it has the VICE Commodore simulator ) . On a large system this idea may not have much merit, but eliminating some unnecessary names on a small system may be worthwhile. At the very least, it's an idea to play with.
: (TYPE) ( ADR CNT -- )
<TYPE> PAUSE ;
: (PTYPE) ( ADR CNT -- )
#LP (CHKOUT) IOERR // SEND TO PRINTER
(TYPE) ;
QTYPE is similar.
SCR# 29
// SYSTEM DEFERRED WORDS & KIN
HEX
// MULTITASKING
DEFER PAUSE ' NOOP IS PAUSE
DEFER ?KEY
DEFER EXPECT
DEFER EMIT
: TYPE (TYPE) PAUSE ;
// QUOTE TYPE
: QTYPE (QTYPE) PAUSE ;
// INITIAL CODE TO BE EXECUTED
DEFER INITIAL ' NOOP IS INITIAL
DEFER ERR ' NOOP IS ERR
DEFER VALID?
DEFER DR/W
DEFER RR/W
SCR# 38
// CONSOLE PRINTER
HEX
: CONSOLE ( -- )
#LP CLOSE CLRCHN
['] (EMIT) IS EMIT
['] (TYPE) (IS) TYPE
['] (QTYPE) (IS) QTYPE
[ HERE >A ]
['] (EXPECT) IS EXPECT ;
: PRINTER ( -- )
#LP CLOSE
0 0 #LP DUP #LP2 (OPEN) IOERR
['] (PEMIT) IS EMIT
['] (PTYPE) (IS) TYPE
['] (PQTYPE) (IS) QTYPE
BRANCH [ A> , ] ; -2 ALLOT
SCR# 39
// LOGGER
HEX
: LOGGER ( -- )
PRINTER
['] (LEMIT) IS EMIT
['] (LTYPE) (IS) TYPE
['] (LQTYPE) (IS) QTYPE
['] (LEXPECT) IS EXPECT ;
: DEFER: ( -- COLON-SYS )
: COMPILE -SET ;CODE
DO-COLON JMP, END-CODE
My implementation of DEFER: for Fleet Forth works but I don't have to implement it for what I'm doing since the words that alter the first cell in the body of TYPE and QTYPE are part of the Fleet Forth system. It is for portable use of this idea outside the system code.
One thing needed changed. -SET is a word that new DEFERred words are set to execute. It aborts showing the name of the word that is not set with the message " NOT SET". If an unset DEFERred word is used from the console, it shows that EXECUTE is not set. This is because EXECUTE doesn't nest and it's not worth the extra code to fix.
-SET works with a DEFERred word but not with a colon definition ( which is what a Fleet Forth DEFER: word effectively is ) so I defined -SET2
I realize that the following would also work:
The first way causes the DEFER: words to have a code field different from colon definitions even though the code pointed to is just a jump to do-colon. This allows words like IS to identify DEFER: words by their code field.
: -SET2
R> // REMOVE ONE LEVEL OF NESTING
BRANCH [ ' -SET >BODY , ] ; // AND BRANCH TO THE BODY OF -SET
-2 ALLOT // RECLAIM MEMORY USED BY UNNEEDED EXIT
: DEFER: ( -- SYS )
: COMPILE -SET2 ;CODE
' : @ JMP, END-CODE
: DEFER: ( -- SYS )
: COMPILE -SET2 ;
JimBoyd wrote:
JimBoyd wrote:
I added to my system loader the version of the Auxiliary stack that grows toward lower memory.
I have four square root words for Fleet Forth in source code on a 'library' disk. SQRT takes an unsigned double number and returns an unsigned single number. DSQRT takes an unsigned quad precision number and returns an unsigned double. They both truncate the result.
The problem is with the versions that round the result. With the truncating versions, the result of the square root of an unsigned double will fit in an unsigned single and the result of the square root of an unsigned quad will fit in an unsigned double. When the square root is rounded, the top 65,000 or so unsigned double numbers will have a result that rounds to 65536 or $10000. The top 4 billion or so unsigned quad precision numbers will return a rounded result that is 4294967296 or $100000000.
If SQRTR , the rounding version of SQRT , returns an unsigned single precision number then the result returned for those top 65,000 or so unsigned double numbers will be zero due to overflow of the result. It could be changed to return a double number to return the entire result. The high cell would be zero most of the time and one for those largest double numbers. Likewise if DSQRTR , the rounding version of SQRT , returns an unsigned double then the result for those 4 billion top numbers will be zero.
It seems odd for the rounding versions to return a different size number than their truncating counterparts. Any suggestions?
I forgot to include this in my explanation:
or maybe they should be:
or even
and I might need better names.
// TRUNCATING
SQRT ( UD -- U )
DSQRT ( UQ -- UD )
// ROUNDING
SQRT ( UD -- U )
DSQRT ( UQ -- UD )
// TRUNCATING
SQRT ( UD -- U )
DSQRT ( UQ -- UD )
// ROUNDING
SQRT ( UD -- UD )
DSQRT ( UQ -- UQ )
// TRUNCATING
SQRT ( UD -- UD )
DSQRT ( UQ -- UQ )
// ROUNDING
SQRT ( UD -- UD )
DSQRT ( UQ -- UQ )
Hmm. Interesting problem - there will always be too many possible answers. Would it be too painful to say that these words return a full precision result, rather than half precision? That feels like the right answer, as the calling program presumably needs to be prepared to use the result, and the result might indeed be too large for half precision.
Is there a means of signalling overflow?
(I'm reminded of the difficulty in fixed-point that -1 is expressible, but +1 is not, so you can't square -1)
- GARTHWILSON
- Forum Moderator
Are the square-root functions primitives or secondaries? Are you willing to make them any longer? Can you just see if the next cell above what you'll return is non-0, and if so, just decrement the returned result from 0 to FFFF (or FFFF:FFFF), keeping in mind that the inputs and outputs are unsigned? (Whether rounded or truncated, the result is usually inexact anyway.) An unconventional alternative would be to return a flag along with the answer, the flag telling if the supposedly rounded answer is actually truncated.
That's a thought - a saturating rounding square root, which returns all-ones as the largest available value.
I don't know if there is prior code that can be a precedent for this.
Here is the code for the truncating square root word SQRT :
The rounding square root word SQRTR :
And the version of the rounding square root word which returns a double:
The version of SQRTR ( the rounding sqrare root word) which returns a double is only ten bytes longer than the one which returns a single.
Well, exact as you can be when discarding the fractional part. With the truncating version, if U squared does not equal UD then UD will be between U squared and (U+1) squared.
HEX
CODE SQRT ( UD -- U )
TYA, 5 # LDY,
BEGIN, N ,Y STA, DEY,
0< UNTIL,
10 # LDY,
BEGIN,
2 ,X ASL, 3 ,X ROL,
0 ,X ROL, 1 ,X ROL,
N ROL, N 1+ ROL,
N 2+ ROL,
2 ,X ASL, 3 ,X ROL,
0 ,X ROL, 1 ,X ROL,
N ROL, N 1+ ROL,
N 2+ ROL,
N 3 + ASL, N 4 + ROL,
N 5 + ROL, SEC,
N 3 + ROL, N 4 + ROL,
N 5 + ROL, SEC,
N LDA, N 3 + SBC,
N 1+ LDA, N 4 + SBC,
N 2+ LDA, N 5 + SBC,
CS IF,
N LDA, N 3 + SBC, N STA,
N 1+ LDA, N 4 + SBC, N 1+ STA,
N 2+ LDA, N 5 + SBC, N 2+ STA,
N 3 + LDA, 2 # ORA, N 3 + STA,
THEN,
N 5 + LSR,
N 4 + ROR, N 3 + ROR,
DEY,
0= UNTIL,
N 3 + LDA, 2 ,X STA,
N 4 + LDA, 3 ,X STA,
POP JMP,
END-CODE
HEX
CODE SQRTR ( UD -- U )
TYA, 5 # LDY,
0< UNTIL,
11 # LDY,
BEGIN,
2 ,X ASL, 3 ,X ROL,
0 ,X ROL, 1 ,X ROL,
N ROL, N 1+ ROL,
N 2+ ROL,
2 ,X ASL, 3 ,X ROL,
0 ,X ROL, 1 ,X ROL,
N ROL, N 1+ ROL,
N 2+ ROL,
N 5 + ROL, SEC,
N 5 + ROL, SEC,
N LDA, N 3 + SBC,
CS IF,
THEN,
N 5 + LSR,
DEY,
0= UNTIL,
N 5 + LSR,
N 3 + LDA, 0 # ADC,
2 ,X STA,
N 4 + LDA, 0 # ADC,
3 ,X STA,
POP JMP,
END-CODE
HEX
CODE SQRTR ( UD -- UD2 )
TYA, 5 # LDY,
0< UNTIL,
11 # LDY,
BEGIN,
2 ,X ASL, 3 ,X ROL,
0 ,X ROL, 1 ,X ROL,
N ROL, N 1+ ROL,
N 2+ ROL,
2 ,X ASL, 3 ,X ROL,
0 ,X ROL, 1 ,X ROL,
N ROL, N 1+ ROL,
N 2+ ROL,
N 5 + ROL, SEC,
N 5 + ROL, SEC,
N LDA, N 3 + SBC,
CS IF,
THEN,
N 5 + LSR,
DEY,
0= UNTIL,
N 5 + LSR,
N 3 + LDA, 0 # ADC,
2 ,X STA,
N 4 + LDA, 0 # ADC,
3 ,X STA,
N 5 + LDA, 0 # ADC,
0 ,X STA,
0 # LDA, 1 ,X STA,
NEXT JMP,
END-CODE
