mojo wrote:
Thanks cbmeeks, that's very generous of you! I'll PM you.
I also have a couple of new projects that might be of interest. One you can have the PCB for the price of shipping. It's a real simple and tiny design with an expansion bus that can be used in a solderless breadboard and other configurations. It has performed well up to 19+ MHz, uses only 5 chips and fits in the palm of you hand. Here are some shots of it in various projects that are underway.
The other is a motherboard type design, but uses a 4-layer board so I'd be a bit hard pressed to give it away. It runs at 16 MHz and through a memory register can address 128K ROM.
PM me if you are interested in either.
Edit: First board corrected to 19+ MHz! Not 291MHz.
Edit-2: mHz corrected to MHz - I'm special....
May I ask the edge connector type? I'm after some just like that for my next project and being swamped by the somewhat sub-optimal searches on mouser/rs/farnell, etc. It's one thing where the old printed catalogues really were a boon to be able to quickly flick through the pictures, then get down to the details..
