Possible Atmel GAL programmer
TomC
Post by TomC »
I just stumbled onto this website, which purports to offer a homebrew programmer for Atmel's 16v8 and 22v10 chips: http://www.bhabbott.net.nz/atfblast.html
You need a computer with a parallel port; maybe he'll upgrade it to use USB at some point.
drogon
Re: Possible Atmel GAL programmer
Post by drogon »
I found that recently, however the real "trick" is knowing the algorithm - the hardware is relatively easy to hook up to e.g. an ATmega (arduino), so it ought to be possible to write the burning code for the ATmega, download the file into it (2K ram - plenty of space) then get it to burn the GAL.
That's my plan, anyway.
whartung
Post by whartung »
What makes these difficult to program? Wacky voltage requirement? Secret undocumented incantations?
DerTrueForce
Post by DerTrueForce »
They use a serial programming algorithm that isn't publicly documented by Atmel/Microchip, and for some reason, it's not available on cheap programmers.
People have reverse-engineered it, though.
DerTrueForce wrote:
They use a serial programming algorithm that isn't publicly documented by Atmel/Microchip, and for some reason, it's not available on cheap programmers. People have reverse-engineered it, though.
I would use their parts if the information were available. Do you have a link to the reverse-engineered algorithm?
DerTrueForce
I do, but not on this device. I've posted it before, though. I'll take a look and see if I can find it again.
EDIT: Here you are: https://www.ecstaticlyrics.com/electronics/ATF22V10C/
Thanks. I just now printed it.
