My opinion on the matter are thus:
While this conversation is interesting to spectate, I don't particularly care whether Doom did full-display redraws, or partial redraws, or delta redraws. It did what it did well enough to create a considerable stir. I do think this conversation highlights the reasons that GPUs became the dominant technology.
Looking to the present, I think being able to access the raw bitmap is nice. I think hardware acceleration for such things as sprites, scrolling, text rendering, and drawing primitives(line, circle, etc) are probably more useful for the types of computers that the members of this site are likely to build. The Gameduino series do some of these things, if I remember correctly. I'm not sure if they do all of them.
Video display controller with VGA output
DerTrueForce
Re: Video display controller with VGA output
I wouldn't be comfortable summarising the members of this site - they are varied, and many are quiet. I think mostly of text-based computing but I like to see graphical patterns and graphs. I have also played some games in my time.
I would expect, in the fullness of time, over the course of years, to see everything here: textual displays, bitmap displays, tiled displays, displays with sprites, displays with VLSI engines, with FPGA engines, with TTL engines. Even vector displays.
There's a project using micro controllers which might be relevant. I've put it in its own thread:
One idea I had was to use dual port RAM for this. The 6502 only accesses RAM on every other cycle anyway and most RAM is much faster than that, so you could probably do a decent 8 bit/pixel bitmap streaming via CPLD, with the other port used for a GPU made from an MCU.
- GARTHWILSON
- Forum Moderator
LDA FOOBAR1
ADC #<some_number>
STA FOOBAR1
JMP <label>http://WilsonMinesCo.com/ lots of 6502 resources
(I imagine mojo meant 'every other phase' - with an adequately fast RAM, the 6502 can share it with other machinery, with no loss of performance.)
Aye, that's what I meant.
Which (and someone correct me if I've mis-remembered) the UK-101 didn't quite get right and you got "snow" over the screen when writing to it due to some fractional timing issues.
I think some CGA hardware had a similar problem. There was a software workaround but I'm not certain whether it eliminated the problem (at a performance cost) or only reduced it.
I settled on a library called SDL which is ostensibly cross-platform, however what it gives is a buffered "poke pixels at the display" type of interface. So I poke pixels into it then call an "update" function which magically blits the software framebuffer I have to the real screen. It can do this very, very fast - even on a Raspberry Pi without using the GPU.
Of-course after doing it, the cool kids told me I was doing it wrong, however it worked very well for me (and still does today), but I know it's "wrong".
