R6501 Disassembler?
dwesti
Re: R6501 Disassembler?
Post by dwesti »
whartung wrote:
The best test of a disassembler is to disassemble code that you have the source code to and check that it matches.
Better to build all opcode set and check disassembler. Same I did with z80, because code has some errors, only in this case i fixed program.
dwesti
Post by dwesti »
Some opcodes. I think I didn't miss anything
opcodes.zip
(1.12 KiB) Downloaded 54 times
