65XX SBC general help and color display help needed
Chromatix
Re: 65XX SBC general help and color display help needed
Post by Chromatix »
I think what I actually said was that I *didn't* think that part was made in a direct equivalent CMOS version.
backspace119
Post by backspace119 »
Right, I mispoke, what I meant was links for the similar parts.
backspace119 wrote:
Just to make sure you're looking at it right— My 4Mx8 10ns 5V SRAM module has (this is copied from the data sheet):
  • eight separate CE\ pins, possibly allowing faster selects by handling the computer's entire address-decoding scheme with programmable logic if desired than you would get from adding a 74xx138 to this plus the computer's other address-decoding logic
  • two WE\ pins, one for each set of four ICs, so your circuit can write-protect half at a time if desired
  • two OE\ pins, one for each set of four ICs (grouped the same way as the WE\ pins)
Any global enable will be in your circuit's logic.
Ya what I mean is, I have OE and WE pins tied together on the module, and I can put their enable on a NAND gate with inputs of A23 and Write/Read that are active high.
You would have to invert either OE or WE, since they're both negative logic.  They'll have to be opposites.
The other chip I'd need to invert A24.
A23?  The 24 address lines are A0 to A23.
A PLL (phase-locked loop) might be another good way to do it, where instead of outputting a number to a DAC to directly feed a VCO, that number is instead the divider for the PLL.  (Of course the PLL has its own VCO too though.)
I looked briefly at PLLs. After reading how they work on wikipedia they seemed to not be a good option though, as from what I read it seems they try and match a reference clock, rather than generate a variable clock.
That's where the divider comes in, as shown in the third diagram in that wikipedia article.  The divider block is labeled "÷N (optional)".  The output frequency then is usually much higher than the input frequency, and goes in multiples of the input.  (What it does not show is that the input could also be divided down, by a different number, adding to the flexibility.)
backspace119
Ya that's what I have set up, I'll attach and image to the end of this.
whoops, ya, I meant a23
I'll go back to the article, after I read that it was used for phase matching I had moved away from it, since msot of the PLLs on mouser were smd packages anyway.
EDIT: forgot the picture
backspace119
So I added in a second 4M module, just to see how the schematic would look (haven't moved back to the PCB yet, want to get the clock situation sorted). and I settled with the circuit at the end of this for the WE and OE connections, to maintain only max 3 gate delays for both devices (as opposed to 4 on the second, having to invert A23 before sending it to the NAND).
EDIT: just to be clear, the WRITE and READ signals in my last post are active high, these signals are WRITE\ and READ\ active low. ( it can be hard to see the lines above them)
whartung
Post by whartung »
backspace119 wrote:
I've been considering the possibility of trying to port the original DOOM to run on this machine.
It's a bit of a running joke to port DOOM to random machines, and it's been done for a lot of crazy stuff. This is by no means a mandatory operation of the design, but it's a fun stretch goal that, if I make it work, would be pretty cool.
A cursory look over some of the requirements to run DOOM tells me that this will be a very difficult task, and is probably out of the realm of possibility. The requirements on x86 are:
  • a 486 running at 66Mhz
    8MB of ram
    about 100MB of storage
    windows 95/98/ME/2k compatible 16bit sound card
Just as an aside, you certainly don't need a 66MHz 486 to run DOOM.
I routinely played it on a 486sx 25Mhz laptop back in the day, and it was developed on a 25Mhz '040 NeXTStation.
Is a 20Mhz '816 enough? I dunno, but you certainly didn't need a 66Mhz machine to play DOOM back in the day.
backspace119
Huh, I'm too young to have played it on the first computer I used (a Pentium II running around 300Mhz) but I have it emulated on a pi powered arcade machine.
20mhz is going to be tough to hit, I'm hoping that I can optimize this well enough to be able to run it though.
backspace119
So I just found this which seems perfect, but it's resistance controlled, and I'm not sure if it can be changed while live yet. Thoughts?
It's the resistance to Vcc.  You should be able to have a set of resistors switched in or out by a VIA's (or similar I/O IC) port bits.  One end of each resistor goes to that pin on the part you found, and the other end of each resistor goes to a VIA port pin.  Put 1's in every relevant bit of the port's output register.  Then to connect the resistor, make the data direction bit an output.  To disconnect it, make it an input.  WDC's 65c22's port pins are truly high-impedance in the input mode, unlike other companies'.  This is not an R-2R ladder.  Every resistor will have a different value.
Arlet
Post by Arlet »
Or use a digital potentiometer. If you get a non-volatile kind, it will remember the setting when the board is powered down.
Some recent ideas in this (long!) thread which might benefit from new dedicated threads:
- continuously-variable clocking of a 6502 system
- porting DOOM to a 6502 system
- Mouser's filtering mixes up surface-mount and through-hole
backspace119
Sweet, so then I can probably use this just fine, the rise time on it looks pretty decent too.
The via idea I'm not sure about, it seems like a waste of via pins for clock control, I may try and find another way to switch out resistance on it.
This is probably what I'll do, the only issue with a non volatile one would be setting a too high clock and not being able to set it back or save myself by just resetting. Also, at power up it needs the slow clock, so if I had a power failure it wouldn't be able to reboot.
Still though, digital pot is probably the way to go, I just wasn't sure if I could change the frequency live.
Good idea, I'll post some more threads about the individual ideas to keep things organized, should I still post them in newbies? Or elsewhere?
Arlet
Post by Arlet »
You could do a jumper in series/parallel so you have the option for manual override.
Great! Not Newbies, I think - this is not getting-started stuff. Choose Hardware or Software forums if it's obvious, or General otherwise.
backspace119
I actually already did that, after I realized that was probably the correct option, mouser is in general, doom in programming, and clock in hardware
