Happy to entertain you.
Here's a related trick which could in some cases be an attractive way of returning altered flags to a bios caller, without relying on stack gymnastics. In
this thread (whose context is 65816), ...
I wrote:
Let's say a bios routine needs to return a yes-no message, either "a" or "b," to the caller. For message "a" the routine exits using RTI, and a one-byte instruction located right after the BRK in the calling code will get executed. But for message "b" the bios routine would exit using PLP followed by RTL [RTS, for 6502], which results in the one-byte instruction following the BRK getting skipped. So, for example, by using CLC or SEC as the conditionally-executed instruction after the BRK you can cause the "message" to end up in the carry flag!
(Carry would have to be in a known state beforehand.)
