1. Though I agree that using a hash prefix is not necessary for immediate operands in your syntax, I think using it makes it easier for a programmer to tell, at a glance, if something is supposed to be a literal number or a label, particularly when such is indirected through an equate, so the number does not actually appear in the instruction's source. Since I can't see it doing any harm either way, you could make it optional; would also make it slightly easier to transform source code from the traditional syntax to your new one.
2. Whilst I have no problem with keeping the existing Branch instruction mnemonics, perhaps it might be possible to have an additional syntax along the lines of
B C,label ; instead of BCS
B !C,label ; instead of BCC
B label ; instead of BRA or BRL
B V,label ; instead of BVS
etc, etc.
3. Similarly, I would suggest XCE -> SCE, in order to match with XBA -> SH, just to keep the "Swap" nomenclature consistent.
4. As the WDM instruction is explicitly stated to be intended for future expansion (even if that's increasingly unlikely to ever happen), I suggest giving WDM an explicitly required signature byte (which could default to a NOP if not specified, if you like), whilst NOPL assembles as a 1-byte instruction for skipping the following, or even rename the latter SKIP to make it even clearer exactly what its for. That way, I feel, the instruction called WDM more closely resembles the intended purpose of the instruction of the same name in the traditional syntax.
