What you can drop is the compare-to-zero instruction. It's an automatic, implied part of the following 65c02 instructions: LDA, LDX, LDY, INC, INX, INY, DEC, DEX, DEY, INA, DEA, AND, ORA, EOR, ASL, LSR, ROL, ROR, PLA, PLX, PLY, SBC, ADC, TAX, TXA, TAY, TYA, and TSX. This means that, for example, a CMP #0 after an LDA, or a CPX #0 after a DEX, is redundant, a wasted instruction. The only time a 65c02 (CMOS) needs a compare-to-zero instruction after one of these is if you want to compare a register that was not involved in the previous instruction; for example,
DEY
CPX #0
(Note the Y and the X are not the same register.) If you can spare a register to which you can transfer the one you want to test, you can save a byte with the transfer instead of a compare instruction. The example above, if the contents of A don't need to be kept, could be changed to:
DEY
TXA
and then you can branch on the N or Z flag which tell if X was negative or zero. The TXA isn't any faster (both TXA and CPX# take two clocks); but TXA takes only one byte, whereas the CPX #0 takes two bytes.
The NMOS 6502 did have a bug in that the flags weren't always correct after a decimal-mode operation like ADC; so then you might have to follow it with the CMP #0 to get the N and Z flags right. It's best to just use the CMOS processor when possible.
(This is from the
programming tips page of my 6502 primer.)
