I'll quote from Bruce Clark's tutorial, since he illustrates it well:
On the 65C02 and NMOS 6502, LDA $12 (direct addressing) and LDA $0012 (absolute addressing) load data from the same address. On the 65C816, this is not always the case. For example, if the DBR is $12, the D register is $3400, and the m flag is 1, then
LDA $56 (direct addressing) loads data from $003456
LDA $0056 (absolute addressing) loads data from $120056
LDA $000056 (long addressing) loads data from $000056
When encountering an operand address whose high byte is $00, almost all 65C02 and NMOS 6502 assemblers will use zero page addressing rather than absolute addressing as an optimization, since this usually saves a byte and a cycle. It is rarely necessary to override this optimization (i.e. to tell the assembler to use absolute addressing).
However, on the 65C816, it is necessary to pay much closer attention to the addressing mode being assembled, as the example above illustrates. An assembler that assembles code for the 65C816, as well as one (or both) of its 8-bit predecessors may perform the aforementioned optimization even for the 65C816, which may be not what you wanted or intended. It may be worthwhile to review the documentation of your assembler to see how to explicitly specify whether direct, absolute, or long addressing will be used.
