The Woz FP routines
The Woz FP routines
For a little project I need a single precision/4-byte solution. (It has to be 4 bytes for other reasons).
I'm probably going to just use the Woz routines, but was wondering if there is any merit in coding an IEEE-754 solution, given the recent thread. The numbers won't be exported in anything other than on-screen so a compatible binary format isn't required.
It's not for anything vaguely critical, just a little interpreter for a bit of fun.
So just wondering if anyone has used/is using the Woz routines on a daily basis if if they're happy with them..
Re: The Woz FP routines
I haven't used them, but I would use them! I lack the sense of impending joy from implementing my own. In other words, I'd say it's worth implementing a floating point package if you really want to implement a floating point package. But not worth it as a means to an end. This is of course only my take on it!
For simple purpose, the Woz routines do work - after all, they shipped in millions of Apple ]['s. They have similar theoretical range and precision to IEEE-754 single precision - with some caveats.
Caveat 1: AFAIK, the Woz routines have no guard digits, and thereby have only a primitive treatment of rounding error. This could seriously hurt practical precision in some cases.
Caveat 2: the Woz format has no support whatsoever for Infinities or NaNs, so must treat overflow, range or other errors with exception traps instead of returning an interpretable value. Conversely, it does have a slightly extended dynamic range for representing finite values.
It would probably be good practice to design your interpreter in such a way that the Woz routines can be swapped out for something else later, in case you find a need or use for something more capable.
Just as suggestion: why don't use the Microsoft 5 bytes f.p. implementation as in commodore line?
http://65xx.unet.bz/ - Hardware & Software 65XX family
Thanks,
Note this fix needed for Woz and Rankin's LOG:
viewtopic.php?p=63993#p63993
BTW, Microsoft's Basic came in a 4 byte version as well as the more commonly seen 5 byte version:
https://www.pagetable.com/?p=46
I imagine there are code size/complexity/speed advantages if all objects are the same size.
- barrym95838
It looks like there's also a 4-byte floating point package in the 6502 Software Gourmet Guide & Cookbook:
http://www.classiccmp.org/cini/books/Sc ... okbook.pdf
(Chapter 5, page 93 of the PDF)
(There's no text layer in this PDF! So lots of typing ahead, or some OCR and proof-reading.)
Edit: also at the Internet Archive, with text layer, here.
If you look at the code, the author does a curious thing.
You see a lot of this:
LDX #LBL1
STA PAGE0, X
LDX #LBL1
STA $0,X
Very odd.
