Delay loops in asembly
I am trying to add HD44780 character display to my 6502 project.
Currently I do not have any timer which could be used for convenient time keeping and implementation of delay loops - it will be added with the next I/O board. Until then I need some workaround, because initialization routine of HD44780 requires several waiting periods, before busy flag becomes accessible.
Is there a easy way to calculate how much time simple loop takes to complete on specific 6502 CPU, clocked with specific frequency? And then execute that loop as many times as necessary? Simply speaking i need an equivalent of delay_us() and delay_ms() functions.
Re: Delay loops in asembly
Is there an easy way? Well, you need to count cycles. You can do that by hand, looking up cycle counts in documentation, or you can run a suitable simulator like visual6502, or (possibly) Kowalski's emulator.
Or, perhaps someone has already done the work... here's a usenet posting:
To convert from cycles to milliseconds, you need to know the clock frequency of your 6502.
For my usual loop:
ldy #ycnt ; (2 cycles)
ldx #xcnt ; (2 cycles)
delay dex ; (2 cycles)
bne delay ; (3 cycles in loop, 2 cycles at end)
dey ; (2 cycles)
bne delay ; (3 cycles in loop, 2 cycles at end)-
JenniferDigital
Don't forget that the times required for the HD44780 and compatibles, as far as I can remember are minimum times, so it's ok to be a few cycles over. Also, there's the busy flag you can use after initialisation. That will allow your code to run as fast as the display will allow.
Last edited by JenniferDigital on Wed Aug 29, 2018 6:08 pm, edited 1 time in total.
- GARTHWILSON
- Forum Moderator
DigitalDunc wrote:
Don't forget that the times required for the HD44780 and compatibles are as far as I can remember are minimum times, so it's ok to be a few cycles over. Also, there's the busy flag ypu can use after initialisation. That will allow your code to run as fast as the display will allow.
- BigDumbDinosaur
... to count cycles... you can run a suitable simulator like visual6502, or (possibly) Kowalski's emulator..
{ } ; delay 9*(256*A+Y)+8 cycles
{ } ; assumes that the BCS does not cross a page boundary
{ 8000 C0 01 } .1 CPY # 1 ; 2
{ 8002 88 } DEY ; 2
{ 8003 E9 00 } SBC # 0 ; 2
{ 8005 D0 F9 } BCS =.1 ; 3
Also, a good exercise for beginners is to analyze this routine and understand how it works (what, for example, is the purpose of the CPY?), and verify that the cycle count formula is correct.
- barrym95838
{ 8002 88 } DEY ; 2
- BigDumbDinosaur
- GARTHWILSON
- Forum Moderator
barrym95838 wrote:
That level of efficiency causes my brain to do a little happy dance. Nicely done, sir!
I think Daryl's latest revision (1.2.14a) addressed the cycle count inaccuracies.
before someone faxed us an ap. note about this. (This was before the internet.)
Like that time my kid first saw a payphone and wondered what it was. LOL
- BigDumbDinosaur
OT: telephony nostalgia
Hey, if you don't know how to operate the round thing, you can always dial by hook-flashing... defeats dial-locks too! So I hear.
In fact, that could be a useful application for a delay loop.
