Using a timer counter as a jiffy clock is perfectly fine - it's what they're designed for. Using one as a source of randomness is not - even if it runs at a different rate to the CPU clock, it's still a *predictable* and *constant* rate with almost no entropy (a theoretical measure of randomness). This would make your RNG useless for straightforward Monte-Carlo analysis, such as rolling some dice or shuffling some cards many times and working out the distribution of results. In fact, the behaviour of the RNG in such a workload would be similar to that of a very poor linear-congruential PRNG, cycling its low-order bits in a short, repeating sequence.
Using a simple LFSR, as described at the beginning of this thread, is a better alternative to that. You could initialise the LFSR on boot with the reading from a persistent RTC chip, if you wanted to avoid repeating sequences every boot.
Someone asked me privately how to use Spritz as the core of an RNG. I think it's best to link to Bruce Schneier's introductory summary of the cryptosystem:
https://www.schneier.com/blog/archives/ ... ew_rc.html and the original authors' paper:
http://people.csail.mit.edu/rivest/pubs/RS14.pdf
As Schneier notes, Spritz is a "sponge function" which can absorb data and then squeeze out a stream of pseudo-random bytes. In the simplest PRNG application, you would "absorb" a seed value - possibly a constant, such as the contents of your boot ROM - and then whenever you need a random value, you just "squeeze" out however many bytes you need to construct your output. The paper explains how to do that in ways which safely distinguish it from its alternative uses in cryptography. If you have a source of true randomness, you simply "absorb" the output from your random source whenever it's available.
One way to build a true random source, which doesn't rely on having human inputs to time, is to AC-couple a suitably biased diode to a comparator, which in turn feeds into a shift register. Occasionally reading and absorbing that shift register's contents should produce enough entropy to keep Spritz output unpredictable. Note that while random, the output of a noise source is not necessarily unbiased; Spritz effectively acts as a "whitening filter" which removes the bias.
