FAT32?
Re: FAT32?
I have 65C816 asm code for partitioning mass storage device (FAT16 partition), limited of course to 2Gb. I tried on some flash card and the new created FAT16 partition work fine in one Windows machine. Algorithm is based on rules described in the paper showed by BDD.
This code make MBR,PBR, FAT's tables and root directory on new partition (fast formatting). A full formatting (clear all cluster's) is frustating (long time).
Of course need of low level routines for read/write sector's and for identify device.
Marco
Marco
http://65xx.unet.bz/ - Hardware & Software 65XX family
Re: FAT32?
ArnoldLayne wrote:
BTW, here is a Microsoft technical paper on the FAT filesystem for those who don't have all the details.
https://www.pjrc.com/tech/8051/ide/fat32.html
Helped me a great deal.
Re: FAT32?
Marco
Marco
Re: FAT32?
Code is available at:
http://65xx.unet.bz/ - software section
direct link: http://65xx.unet.bz/mb01/B1606.zip
This code is a work in progress. Many pieces are incomplete, maybe full of bugs, but some sections are fully tested.
About FAT16 i'm developing a simple system for caching directory entries and accessed sector's for fast access. Traversing directories is still incomplete, but code for partitioning/formatting FAT16 is fully tested (also, work in floppy disk both 720K/1440K).
Look at F9/toscmd.asm for 'fdisk' implementation.
Note that low level routines for accessing ATA devices, USB devices (CH375/376 module) and floppy disk are in F8 directory. In this implementation ATA devices are accessed in DMA mode even if in the site is not showen the new ATA/DMA board i maded for my machine.
Marco
Marco
Re: FAT32?
dolomiah wrote:
whartung wrote:
That's pretty nice.
I read the manual, I couldn't see a command to format disks, but looks like block level access is possible - as you say, loads of possibilities.
What kind of CRC are you using for the FAT32?
Re: FAT32?
kakemoms, are you referring to my 6502 homebrew source on hackaday, or what granati posted? Reason I am slightly confused is your reference to FAT32 - my code only supports FAT16.
But in case you are referring to my source code, yes from what I read and what is working, the SD card doesn't seem to care about the CRC after the CMD0. Weird, but works according to the document I found on this (an application note from 2004 by F. Foust, published by the University of Michigan). 0x95 is the correct CRC for CMD0, so I then just send the same value with all subsequent commands (ignore the comments that say the checksum has to be right, it's a copy and paste error!)
Regarding FAT32 CRC, well that's where I am confused as my code only supports FAT16 and there is no CRC in that. I am not sure there is any CRC in FAT32 mind..
Re: FAT32?
I still don't understand why CRC is not used. FAT seems to make double copies of the file allocation table as a redundancy.. and that indicates that CRC would probably be a good idea.
There are several places that lists command arguments and CRC, so it seems like a table is all that is needed for most commands.
Re: FAT32?
Ok, since I couldn't find any CRC-7 for 6502, I made one myself:
Probably not the fastest way, but it seems to work.
; Calculation of CRC7 for SD Card communication
CMD0 = $40
*=$a000
LDA #CMD0 ; CMD0 command (no arguments)
STA crcdata
LDA #4
LDX #<crcdata
LDY #>crcdata
JSR crc7
ASL ; CRC for SPI in bit 7-1
ORA #1 ; bit0 always set
STA crcdata+5
RTS
crcdata byte 0,0,0,0,0,0
; start of data is in X & Y
; length-1 is in A
crc7
STX $2
STY $3
STA $4
LDX #0
STX $5 ;crc
STX $6 ; counter
crc7lp1
LDY $6
LDA ($2),Y ; get ch
LDX #7
crc7lp2
TAY
ASL $5 ; shift CRC
EOR $5 ; CH XOR CRC
AND #$80
BEQ crc7mp1 ; if (CH XOR CRC) AND $80 = 0
LDA $5
EOR #$09
STA $5 ; CRC = CRC XOR $09
crc7mp1
TYA ; CH
ASL ; shift CH
DEX
BPL crc7lp2 ; loop 7 times
LDA $5
AND #$7f
STA $5 ; CRC = CRC AND $7F
INC $6
DEC $4
BPL crc7lp1
LDA $5 ; CRC
RTS- BitWise
- In Memoriam
Re: FAT32?
I'm not sure that you really need a CRC7 routine. The series of commands you send to initialise the SC card are always the same so the CRC7 bytes can be pre-computed. Later when accessing the card to read/write blocks the CRC16 values are optional.
I can't find the 6502 code I wrote for my SBC when I was playing with this last year. I'll try to dig it up later.
Andrew Jacobs
- BitWise
- In Memoriam
Re: FAT32?
Heres the listing of the code I wrote that initialises an SD card and read/dumps a 512 byte sector. One day I'll get back to it.
This was for my SB-6502 board and its virtual SPI65 interface. All the CRC7 values are fixed in the initialisation data.
Andrew Jacobs
ArnoldLayne
Re: FAT32?
kakemoms wrote:
Sorry I got the code mixed up here (my brain is still in holiday mode). The FAT32 question was to the other coder with the SteckOS.
Where one CRC7 checksum IS indeed needed is when using the SD card command CMD0 during SD card init, but not need to generate one because it always the same, as BitWise already pointed out.
Or was there another question I missed?
ArnoldLayne
Re: FAT32?
Re: FAT32?
ArnoldLayne wrote:
Hi,
we are working our own FAT32 implementation as part of the operating system "SteckOS" for our 6502-based homebrew computer "Steckschwein" http://www.steckschwein.de
It's not complete yet, we currently do not follow cluster chains, so files > 1 cluster are a problem.
We chose not to support long file names either.
But creating, reading, writing files and directories works. The "API" is loosely modeled after POSIX (open,close,read,write).
The code is publicly available: https://bitbucket.org/steckschwein/stec ... os/kernel/
Our implementation only needs a means to read and write (512 byte)blocks and a few memory locations.
Thomas
Thomas
I am grinding through your code, and mostly its easy reading. Only a few 65c02 specific instructions, so they are easy to replace. At least up until now. Then I came accross this code segment which makes less sense to me:
path_inverse:
stz krn_tmp
stz krn_tmp2
ldy #0
jsr l_inv
iny
lda #0
sta (krn_ptr2),y
rts
l_inv:
lda (krn_ptr3), y
iny
cpy krn_tmp3
beq l_seg
cmp #'/'
bne l_inv
phy
jsr l_inv
ply
sty krn_tmp
l_seg:
ldy krn_tmp
inc krn_tmp
lda (krn_ptr3), y
ldy krn_tmp2
inc krn_tmp2
sta (krn_ptr2), y
cmp #'/'
bne l_seg
rts-
ArnoldLayne
Re: FAT32?
kakemoms wrote:
The jsr instruction that goes back to its own code segment seems somewhat untraditional. Could you explain what is happening here?
The Steckschwein Project is a team effort, and that happens to be not my code. Looks like some kind of recursion to resolve a file path to me.
Let me try to convince my teammate to register here to have him explain it himself.
ArnoldLayne
Re: FAT32?
https://bitbucket.org/steckschwein/stec ... l/util.asm
