Macroassembler by Michal Kowalski, syntacs question
- barrym95838
Re: Macroassembler by Michal Kowalski, syntacs question
I support the notion that a BRK by itself should assemble to a $00 by itself, and a BRK #$EA should assemble to $00 $EA without complaint ... now I just need to write or modify an assembler to support that behavior, because expecting someone else to do it for me at this late date would be vainly optimistic.
- BigDumbDinosaur
It would indeed be logical to assemble "BRK #0" as 00 00, and some assemblers accept that syntax, but that's not what was specified here. This difference from standard assembler behaviour could indeed be considered a bug.
The code given was
BRK NOP NOPCode: Select all
00 00 EA EACode: Select all
00 EA EA EACode: Select all
BRK #0Code: Select all
00 00x86? We ain't got no x86. We don't NEED no stinking x86!
You can set the BRK opcode behavior here:
This is what macros are for:
; BRK instruction to assemble with or without signature
; no matter what the assembler thinks it should do
myBRK .macro ...
.db 0
.if %0>0
.db %1
.endif
.endm
; usage example
*=$200
myBRK ; native BRK
myBRK $12 ; BRK with signature byte
.end
- BitWise
- In Memoriam
Dev65 generates one byte unless an immediate operand is specified.
00:00C4' 00 : BRK
00:00C5' 0011 : BRK #$11
Andrew Jacobs
Best of both worlds!
