It is currently Tue Jun 04, 2024 10:05 am
PostPosted: Thu Jul 19, 2018 9:31 am
This bug was discovered here:
viewtopic.php?f=1&t=5198&start=150#p61372
The "result" for EhBasic using: 40 IF INT(C/D)*D = C THEN NEXT C : GOTO 90
yields: "NEXT without FOR Error in line 40"
This is true not only for a NEXT but also for LOOP and RETURN. All of these keywords need to find their FOR, DO or GOSUB structure on the stack. Since EhBASIC allows for an ELSE the call to interpret a basic statement after THEN must return to IF to be able to skip the program past ELSE. This puts a return address on the stack and breaks the offset to FOR, DO and GOSUB structures on the stack. Interestingly Lee already fixed this for RETURN since there is no need to skip anything after a RETURN.
The fix I have is to simply discard the original call to the "interpret statement" routine (The one that executed the IF) and replace the final RTS with a JMP to the interpreter loop. This also eliminates the need to have a separate fix for RETURN. To my big surprise even nested IFs work correctly.
; perform IF
LAB_IF
      JSR   LAB_EVEX          ; evaluate the expression
      JSR   LAB_GBYT          ; scan memory
      CMP   #TK_THEN          ; compare with THEN token
      BEQ   LAB_174B          ; if it was THEN go do IF
                              ; wasn't IF .. THEN so must be IF .. GOTO
      CMP   #TK_GOTO          ; compare with GOTO token
      BNE   LAB_16FC          ; if it wasn't GOTO go do syntax error
      LDX   Bpntrl            ; save the basic pointer low byte
      LDY   Bpntrh            ; save the basic pointer high byte
      JSR   LAB_IGBY          ; increment and scan memory
      BCS   LAB_16FC          ; if not numeric go do syntax error
      STX   Bpntrl            ; restore the basic pointer low byte
      STY   Bpntrh            ; restore the basic pointer high byte
LAB_174B
      LDA   FAC1_e            ; get FAC1 exponent
      BEQ   LAB_174E          ; if the result was zero go look for an ELSE
      JSR   LAB_IGBY          ; else increment and scan memory
      BCS   LAB_174D          ; if not numeric go do var or keyword
LAB_174C
      JMP   LAB_GOTO          ; else was numeric so do GOTO n
                              ; is var or keyword
LAB_174D
; *** patch       allow NEXT, LOOP & RETURN to find FOR, DO or GOSUB structure on stack
; *** replace
;      CMP   #TK_RETURN        ; compare the byte with the token for RETURN
;      BNE   LAB_174G          ; if it wasn't RETURN go interpret BASIC code from (Bpntrl)
;                              ; and return to this code to process any following code
;      JMP   LAB_1602          ; else it was RETURN so interpret BASIC code from (Bpntrl)
;                              ; but don't return here
;LAB_174G
;      JSR   LAB_15FF          ; interpret BASIC code from (Bpntrl)
;; the IF was executed and there may be a following ELSE so the code needs to return
;; here to check and ignore the ELSE if present
;      LDY   #$00              ; clear the index
;      LDA   (Bpntrl),Y        ; get the next BASIC byte
;      CMP   #TK_ELSE          ; compare it with the token for ELSE
;      BEQ   LAB_DATA          ; if ELSE ignore the following statement
;; there was no ELSE so continue execution of IF <expr> THEN <stat> [: <stat>]. any
;; following ELSE will, correctly, cause a syntax error
;      RTS                     ; else return to the interpreter inner loop
; *** with
      PLA                     ; discard interpreter loop return address
      PLA                     ; so data structures are at the correct stack offset
      JSR   LAB_GBYT          ; restore token or variable
      BNE   LAB_no_ELSE       ; no - continue on this line
      JSR   LAB_DATA          ; yes - skip the rest of the line
LAB_no_ELSE
      JMP LAB_15C2            ; return to the interpreter inner loop
; *** end patch  allow NEXT, LOOP & RETURN to find FOR, DO or GOSUB structure on stack
; perform ELSE after IF
LAB_174E
PostPosted: Thu Jul 19, 2018 2:44 pm
Klaus,
You are the master at fixing EhBASIC. :-)
Have you ever thought about rolling your own BASIC?
PostPosted: Thu Jul 19, 2018 4:00 pm
Thanks Klaus,
I've added this patch to the EhBasic I'm working with... I'm guessing this would now be Version 2.22p5?
PostPosted: Fri Jul 20, 2018 10:40 am
I just released the accumulated patches as 2.22p4 on GitHub.
No, I am not looking for a new challenge.
PostPosted: Fri Jul 20, 2018 11:42 am
Thanks Klaus, fine work.
