bi directional shift register!
Post by 1202 »
Ok will this work?
e.g. a 74ls299 bi directioanl shift register!
Ok I hear that bi directional shift registers have a hold feature, does this mean - can I write data to the parallel lines as input (then hold that data) and then clock it out serially.
e.g. I have a e2prom setup(other circuit), I put the e2prom in read mode and the bi directional shift register latches the data! I then disable the e2prom - effective 0 volts on its data lines right!!
can I therefore hold that data I read before on the bi directional shift register and clock it out serially without loosing it - I'm guessing this will work so long as I disable chip select on the e2prom before doing so.
thoughts?
Its just an enhancement I want to make to my homemade programmer hopefully.
:roll:
NPastoll
1202
update! Note:
Post by 1202 »
Note I want to know if this is ok because I want to use the same clock for both my address network and the bi directional shift register for the data network.
again I'm thinking of once the e2prom is setup, have it in readmode CS enabled!
the data then goes to the bi directional shift register, I then CS disable! (I then want to know if this data will stay latched ok on the chip and then use the clock to serially shift it out the other end)
thanks!
:roll:
NPastoll
1202
might do the same idea with 2 ICS
Post by 1202 »
It's proven easier and cheaper for me to get 2 IC's
serial to parallel & vise versa.
same idea though..
NPastoll
What do you plan to connect the serial end of the shift registers to?
1202
reply to what do you plan?
Post by 1202 »
Parallel port - I have another Idea, I'll get back to you.
NPastoll
1202
I'm going to use..
Post by 1202 »
I'm going to use 74ls165 which has clocking input latch
NPastoll
