cynlic wrote:
I think this question stems from my ignorance of some implementation details (I looked up a few data-sheets of various counters and was still confused) but if the phase accumulator is tied to the same Φ2 as the CPU, doesn't that clock-speed impact the lowest representable frequency? Taking Garth's example, using a 16bit accumulator to index into an 8bit memory address space, the slowest sample period is 1 sample per 256 16bit increments. But isn't the speed of that incrementation dependent upon the Φ2? It seems to me like you could easily overshoot and make it impossible to represent the lower frequency range. I assume that carefully adjusting the Φ2 and the number of bits used by the counter could result in something that’s “just right,” representing the necessary range of frequencies, but I don’t think that’s what everyone is saying should be done.
There are more complicated things with although interesting, probably would not be addressed on a 6502-based synth, like the fact that with some instruments like flute and recorder, the color of the sound cycles with the pitch in vibrato, getting more airy and complex in the higher portion of the cycle. We also have not taken into account the attack sound for beginning notes on various instruments; but again that's getting pretty complicated, and if controlled by a keyboard, would definitely need one that senses how quickly the key went down, or some variation on that theme.
