This paper http://www.ncsu.edu/wcae/WCAE1/hanson.pdf contains a much more detailed block diagram for the 6502 than is present in any of the data sheets (see last page). You can see the same image here http://www.pagetable.com/?p=39 as well - but a bit quicker.
You can see from the diagram how the ALU uses a inverters on the second input to ones-complement before addition to generate a subtraction, and has a completely seperate module for decimal adjustment.
I can feel some VHDL coming on.
**Edit Added alternative link.
Detailed 6502 block diagram
- BitWise
- In Memoriam
Andrew Jacobs
- BitWise
- In Memoriam
kc5tja wrote:
Upon accessing the link, however, I get permission denied message.
Andrew Jacobs
Re: Detailed 6502 block diagram
BitWise wrote:
This paper contains a much more detailed block diagram for the 6502 than is present in any of the data sheets (see last page).
(this topic is the top hit for 6502 block diagram)
