C02 - An 8-bit optimized C syntax compiler for the 6502
Yes, it's yet another language/compiler for the 6502 of dubious usefulness.
This has been a pet project of mine for quite a few years. I finally doubled down and started seriously developing it last summer, and got the code into a state that is hopefully useable by someone other than myself and put in on GitHub this week.
You can find it at https://github.com/RevCurtisP/C02.
The alpha version of the compiler is written in C, but as the code is currently a hacked together mess, I plan to do a complete rewrite, which I may do in C02, so it can be a native compiler.
I've made a number of design decisions that cause this language to diverge from C in some unusual ways, some of which I am questioning, so I plan to ask for advice and/or opinions.
I plan to post some example code in the next couple days so that you don't have to read through all the documentation.
Re: C02 - An 8-bit optimized C syntax compiler for the 6502
Thanks for posting. I will take a look.
A self-hosted version of this would be really neat.
DerTrueForce
This looks like an interesting project. Something like C, and in the spirit of C, but targeted at 8-bit devices instead of 16 or wider.
I agree with Martin_H. Being able to have it self-host could be very useful.
It might be interesting to test the efficiency of its compiled code against another C compiler that targets the 6502. Cc65 is one, I think.
I compiled a Hello World program in both CC65 and C02, targeting the VIC 20.
The C code used with CC65 compiled to 777 bytes total.
The C02 code compiled to 188 bytes.
#include <stdio.h>
#include <stdlib.h>
const char text[] = "hello world!\n";
int main (void)
puts(text);
return EXIT_SUCCESS;
#include "include/vic20.h02"
#include <stdio.h02>
char text = "HELLO WORLD!";
main:
putln(&text);
goto exit;
This was an incredibly trivial example and the generated code was actually very similar.
CC65 .s file
C02 .asm file
so in this case the difference must be in the included library.
CC65 .s file
_text:
.byte $48,$45,$4C,$4C,$4F,$20,$57,$4F,$52,$4C,$44,$21,$0D,$00
lda #<(_text)
ldx #>(_text)
jsr _puts
ldx #$00
txa
rts
MAIN: LDY #>TEXT ;MAIN: PUTLN(&TEXT
LDX #<TEXT
JSR PUTLN ;);
JMP EXIT ;GOTO EXIT;
TEXT: DC $48,$45,$4C,$4C,$4F,$20,$57,$4F,$52,$4C,$44,$21,$00
Once of the goals of C02 is to be completely system agnostic and independent of any specific system libraries.
For example, I've created a header file that contains just a VIC 20 Basic stub and either hooks or aliases functions to the routines built into the ROM.
This code compiled to a total of 60 bytes.
This is what the generated code looks like.
#include "include/vic20bas.h02"
main:
strout(&text);
chrout($0D);
goto exit;
CHROUT EQU $FFD2 ;Output Character to Channel
;Machine Language Basic Stub
ORG $1001 ;Start
BASIC: DC $0C, $10 ; Pointer to Next Line (4108)
DC $00, $00 ; Line Number (0)
DC $9E ; SYS
DC $20 ; ' '
DC $34, $31, $31 ,$30 ; "4110"
DC $00 ;End of Line Marker
DC $00, $00 ;End of Basic Program
START: TSX ;Get Stack Pointer
STX STKPTR ;and Save for Exit
JMP MAIN ;Execute Program
STKPTR: DS 1
EXIT: LDX STKPTR ;Retrieve Saved Stack Pointer
TXS ;and Restore It
RTS ;Return to BASIC
;System Routine Hooks
STROUT: TXA ;Move Low Byte from X to A
JMP $CB1E ;Print String at Address in Y and A
MAIN: LDY #>TEXT ;MAIN: STROUT(&TEXT
LDX #<TEXT
JSR STROUT ;);
LDA #$0D ;CHROUT($0D
JSR CHROUT ;);
This sounds really neat! Could you see how compiled code compares when you do loops and calculations? How about something along these lines:
int i,j,result;
for (i=0;i<10;i++)
for (j=0;j<10;j++)
result=(i*10+j)*9/5+32;
printf("%d\n",result);
}Re: C02 - An 8-bit optimized C syntax compiler for the 6502
int i,j,result;
for (i=0;i<10;i++)
for (j=0;j<10;j++)
}Basically, the parser converts the expression into an LDA or JSR(s) followed by a series of ADC, SBC, AND, ORA, and EOR instructions.
To profile the above code, I will need to make the numbers a bit smaller so that interim results will fit in the range 0-255, and refactor the expression to work within the limits of C02. The parameters to printf are also reversed because of C02's calling convention for functions. In addition, escapes in strings are handled literally, so '\n' will not produce a newline on most 6502 systems. The current solution is to call the system-specific newlin() function.
So this is what the C02 code ends up looking like
char i,j,result;
for (i=0;i<5;i++) {
for (j=0;j<5;j++) {
result=div(mult(mult(i,5)+j,3),5)+32; //(i*5+j)*3/5+32;
printf(result,"%d");
newlin();
char i,j,result;
for (i=0;i<5;i++) {
for (j=0;j<5;j++) {
result=(i*5+j)*3/5+32;
For the loops, C02 produces the code
and CC65 produces
LDA #$00 ;MAIN: FOR (I=0
STA I ;;
L_0000: LDA I ;I
CMP #$05 ;<5
BCC L_0003
JMP L_0001 ;;
L_0002: INC I ;I++)
JMP L_0000
L_0003: LDA #$00 ;{ FOR (J=0
STA J ;;
L_0004: LDA J ;J
CMP #$05 ;<5
BCC L_0007
JMP L_0005 ;;
L_0006: INC J ;J++)
JMP L_0004
L_0007: //body of for loops
L_0005: JMP L_0002 ;}
L_0001: //continue code
ldx #$00
lda #$00
sta _i
L0002: ldx #$00
lda _i
cmp #$05
jsr boolult
jne L0005
jmp L0003
L0005: ldx #$00
lda #$00
sta _j
L000A: ldx #$00
lda _j
cmp #$05
jsr boolult
jne L000D
jmp L0004
L000D: //body of for loops
L0004: ldx #$00
lda _i
inc _i
jmp L0002
L0003: ldx #$00
lda #$00
jmp L0001
L0001: //continue with program
For the expression evaluation and subsequent assignment, we get the following:
From C02 (28 bytes)
and from CC65 (40 bytes)
As you can see, C02 translates the code to 6502 operations as closely as possible, while CC65 calls a subroutine for every operation, and it promotes the values to 16-bits then casts them back to 8-bits.
From C02 (28 bytes)
LDA I ;{ RESULT=DIV(MULT(MULT(I
LDY #$05 ;,5
JSR MULT ;)
CLC ;+J
ADC J
LDY #$03 ;,3
JSR MULT ;)
LDY #$05 ;,5
JSR DIV ;)
CLC ;+32
ADC #$20
STA RESULT ;;
ldx #$00
lda _i
jsr mulax5
jsr pushax
ldx #$00
lda _j
jsr tosaddax
jsr mulax3
jsr pushax
ldx #$00
lda #$05
jsr tosudivax
ldy #$20
jsr incaxy
ldx #$00
sta _result
Finally, there is the printing code:
C02 produces
and CC65 produces
C02 produces
LDA RESULT ;PRINTF(RESULT
LDY #>L_0008 ;,"%d"
LDX #<L_0008
JSR PRINTF ;);
JSR NEWLIN ;NEWLIN();
L_0008: DC $25,$64,$00
lda #<(L0016)
ldx #>(L0016)
jsr pushax
ldx #$00
lda _result
jsr pushax
ldy #$04
jsr _printf
L0016:
.byte $25,$64,$0A,$00
DerTrueForce
I'm no expert, but that looks like C02 is a winner, certainly for code density.
One thing that I noticed is that there are no shift or rotate commands in C02. Is this because there is no way to shift multiple bits in one 6502 instruction?
EDIT: I just checked the docs again, and I see that there are bit-shift instructions. No rotates, but that does make a sense now that I think about it, since the 6502 rotates through the carry bit.
I still think I'd like to use C02 in my project, especially if it runs on the 'C02 as well.
Thinking of which, the name might be a touch awkward, due to the use of 'C02(with the apostrophe) to refer to the 65C02, at least around here). I'm not saying you have to change the name(and I think it's a good one), but might "C-02" work? I think it would differentiate it from the local slang a little more clearly.
As long as you don't need 16-bit math, it should work pretty well.
At the very least I should rename the compiler cc02, to match cc, gcc, tcc, etc...
The intention of the language is that the fiddly parts will be written in assembler and called as functions. And the general program flow and overall logic written in C02.
