It is currently Sat Nov 23, 2024 8:14 am
PostPosted: Sat Jan 06, 2018 4:55 pm
HI all,
Does anyone have a correct and complete list of available page 0 locations for EhBasic 2.22?
PostPosted: Sat Jan 06, 2018 10:05 pm
00045    ; zero page use ..
00046
00047      0000             LAB_WARM       = $00      ; BASIC warm start entry point
00048      0001             Wrmjpl       = LAB_WARM+1; BASIC warm start vector jump low byte
00049      0002             Wrmjph       = LAB_WARM+2; BASIC warm start vector jump high byte
00050
00051      000A             Usrjmp      = $0A      ; USR function JMP address
00052      000B             Usrjpl      = Usrjmp+1   ; USR function JMP vector low byte
00053      000C             Usrjph      = Usrjmp+2   ; USR function JMP vector high byte
00054      000D             Nullct      = $0D      ; nulls output after each line
00055      000E             TPos         = $0E      ; BASIC terminal position byte
00056      000F             TWidth      = $0F      ; BASIC terminal width byte
00057      0010             Iclim         = $10      ; input column limit
00058      0011             Itempl      = $11      ; temporary integer low byte
00059      0012             Itemph      = Itempl+1   ; temporary integer high byte
00060
00061      0011             nums_1      = Itempl   ; number to bin/hex string convert MSB
00062      0012             nums_2      = nums_1+1   ; number to bin/hex string convert
00063      0013             nums_3      = nums_1+2   ; number to bin/hex string convert LSB
00064
00065      005B             Srchc         = $5B      ; search character
00066      005B             Temp3         = Srchc   ; temp byte used in number routines
00067      005C             Scnquo      = $5C      ; scan-between-quotes flag
00068      005C             Asrch         = Scnquo   ; alt search character
00069
00070      005B             XOAw_l      = Srchc   ; eXclusive OR, OR and AND word low byte
00071      005C             XOAw_h      = Scnquo   ; eXclusive OR, OR and AND word high byte
00072
00073      005D             Ibptr         = $5D      ; input buffer pointer
00074      005D             Dimcnt      = Ibptr   ; # of dimensions
00075      005D             Tindx         = Ibptr   ; token index
00076
00077      005E             Defdim      = $5E      ; default DIM flag
00078      005F             Dtypef      = $5F      ; data type flag, $FF=string, $00=numeric
00079      0060             Oquote      = $60      ; open quote flag (b7) (Flag: DATA scan; LIST quote; memory)
00080      0060             Gclctd      = $60      ; garbage collected flag
00081      0061             Sufnxf      = $61      ; subscript/FNX flag, 1xxx xxx = FN(0xxx xxx)
00082      0062             Imode         = $62      ; input mode flag, $00=INPUT, $80=READ
00083
00084      0063             Cflag         = $63      ; comparison evaluation flag
00085
00086      0064             TabSiz      = $64      ; TAB step size (was input flag)
00087
00088      0065             next_s      = $65      ; next descriptor stack address
00089
00090                   ; these two bytes form a word pointer to the item
00091                   ; currently on top of the descriptor stack
00092      0066             last_sl      = $66      ; last descriptor stack address low byte
00093      0067             last_sh      = $67      ; last descriptor stack address high byte (always $00)
00094
00095      0068             des_sk      = $68      ; descriptor stack start address (temp strings)
00096
00097    ;         = $70      ; End of descriptor stack
00098
00099      0071             ut1_pl      = $71      ; utility pointer 1 low byte
00100      0072             ut1_ph      = ut1_pl+1   ; utility pointer 1 high byte
00101      0073             ut2_pl      = $73      ; utility pointer 2 low byte
00102      0074             ut2_ph      = ut2_pl+1   ; utility pointer 2 high byte
00103
00104      0071             Temp_2      = ut1_pl   ; temp byte for block move
00105
00106      0075             FACt_1      = $75      ; FAC temp mantissa1
00107      0076             FACt_2      = FACt_1+1   ; FAC temp mantissa2
00108      0077             FACt_3      = FACt_2+1   ; FAC temp mantissa3
00109
00110      0076             dims_l      = FACt_2   ; array dimension size low byte
00111      0077             dims_h      = FACt_3   ; array dimension size high byte
00112
00113      0078             TempB         = $78      ; temp page 0 byte
00114
00115      0079             Smeml         = $79      ; start of mem low byte      (Start-of-Basic)
00116      007A             Smemh         = Smeml+1   ; start of mem high byte   (Start-of-Basic)
00117      007B             Svarl         = $7B      ; start of vars low byte   (Start-of-Variables)
00118      007C             Svarh         = Svarl+1   ; start of vars high byte   (Start-of-Variables)
00119      007D             Sarryl      = $7D      ; var mem end low byte      (Start-of-Arrays)
00120      007E             Sarryh      = Sarryl+1   ; var mem end high byte      (Start-of-Arrays)
00121      007F             Earryl      = $7F      ; array mem end low byte   (End-of-Arrays)
00122      0080             Earryh      = Earryl+1   ; array mem end high byte   (End-of-Arrays)
00123      0081             Sstorl      = $81      ; string storage low byte   (String storage (moving down))
00124      0082             Sstorh      = Sstorl+1   ; string storage high byte   (String storage (moving down))
00125      0083             Sutill      = $83      ; string utility ptr low byte
00126      0084             Sutilh      = Sutill+1   ; string utility ptr high byte
00127      0085             Ememl         = $85      ; end of mem low byte      (Limit-of-memory)
00128      0086             Ememh         = Ememl+1   ; end of mem high byte      (Limit-of-memory)
00129      0087             Clinel      = $87      ; current line low byte      (Basic line number)
00130      0088             Clineh      = Clinel+1   ; current line high byte   (Basic line number)
00131      0089             Blinel      = $89      ; break line low byte      (Previous Basic line number)
00132      008A             Blineh      = Blinel+1   ; break line high byte      (Previous Basic line number)
00133
00134      008B             Cpntrl      = $8B      ; continue pointer low byte
00135      008C             Cpntrh      = Cpntrl+1   ; continue pointer high byte
00136
00137      008D             Dlinel      = $8D      ; current DATA line low byte
00138      008E             Dlineh      = Dlinel+1   ; current DATA line high byte
00139
00140      008F             Dptrl         = $8F      ; DATA pointer low byte
00141      0090             Dptrh         = Dptrl+1   ; DATA pointer high byte
00142
00143      0091             Rdptrl      = $91      ; read pointer low byte
00144      0092             Rdptrh      = Rdptrl+1   ; read pointer high byte
00145
00146      0093             Varnm1      = $93      ; current var name 1st byte
00147      0094             Varnm2      = Varnm1+1   ; current var name 2nd byte
00148
00149      0095             Cvaral      = $95      ; current var address low byte
00150      0096             Cvarah      = Cvaral+1   ; current var address high byte
00151
00152      0097             Frnxtl      = $97      ; var pointer for FOR/NEXT low byte
00153      0098             Frnxth      = Frnxtl+1   ; var pointer for FOR/NEXT high byte
00154
00155      0097             Tidx1         = Frnxtl   ; temp line index
00156
00157      0097             Lvarpl      = Frnxtl   ; let var pointer low byte
00158      0098             Lvarph      = Frnxth   ; let var pointer high byte
00159
00160      0099             prstk         = $99      ; precedence stacked flag
00161
00162      009B             comp_f      = $9B      ; compare function flag, bits 0,1 and 2 used
00163                   ; bit 2 set if >
00164                   ; bit 1 set if =
00165                   ; bit 0 set if <
00166
00167      009C             func_l      = $9C      ; function pointer low byte
00168      009D             func_h      = func_l+1   ; function pointer high byte
00169
00170      009C             garb_l      = func_l   ; garbage collection working pointer low byte
00171      009D             garb_h      = func_h   ; garbage collection working pointer high byte
00172
00173      009E             des_2l      = $9E      ; string descriptor_2 pointer low byte
00174      009F             des_2h      = des_2l+1   ; string descriptor_2 pointer high byte
00175
00176      00A0             g_step      = $A0      ; garbage collect step size
00177
00178      00A1             Fnxjmp      = $A1      ; jump vector for functions
00179      00A2             Fnxjpl      = Fnxjmp+1   ; functions jump vector low byte
00180      00A3             Fnxjph      = Fnxjmp+2   ; functions jump vector high byte
00181
00182      00A2             g_indx      = Fnxjpl   ; garbage collect temp index
00183
00184      00A3             FAC2_r      = $A3      ; FAC2 rounding byte
00185
00186      00A4             Adatal      = $A4      ; array data pointer low byte
00187      00A5             Adatah      = Adatal+1   ; array data pointer high  byte
00188
00189      00A4             Nbendl      = Adatal   ; new block end pointer low byte
00190      00A5             Nbendh      = Adatah   ; new block end pointer high  byte
00191
00192      00A6             Obendl      = $A6      ; old block end pointer low byte
00193      00A7             Obendh      = Obendl+1   ; old block end pointer high  byte
00194
00195      00A8             numexp      = $A8      ; string to float number exponent count
00196      00A9             expcnt      = $A9      ; string to float exponent count
00197
00198      00A8             numbit      = numexp   ; bit count for array element calculations
00199
00200      00AA             numdpf      = $AA      ; string to float decimal point flag
00201      00AB             expneg      = $AB      ; string to float eval exponent -ve flag
00202
00203      00AA             Astrtl      = numdpf   ; array start pointer low byte
00204      00AB             Astrth      = expneg   ; array start pointer high  byte
00205
00206      00AA             Histrl      = numdpf   ; highest string low byte
00207      00AB             Histrh      = expneg   ; highest string high  byte
00208
00209      00AA             Baslnl      = numdpf   ; BASIC search line pointer low byte
00210      00AB             Baslnh      = expneg   ; BASIC search line pointer high  byte
00211
00212      00AA             Fvar_l      = numdpf   ; find/found variable pointer low byte
00213      00AB             Fvar_h      = expneg   ; find/found variable pointer high  byte
00214
00215      00AA             Ostrtl      = numdpf   ; old block start pointer low byte
00216      00AB             Ostrth      = expneg   ; old block start pointer high  byte
00217
00218      00AA             Vrschl      = numdpf   ; variable search pointer low byte
00219      00AB             Vrschh      = expneg   ; variable search pointer high  byte
00220
00221      00AC             FAC1_e      = $AC      ; FAC1 exponent
00222      00AD             FAC1_1      = FAC1_e+1   ; FAC1 mantissa1
00223      00AE             FAC1_2      = FAC1_e+2   ; FAC1 mantissa2
00224      00AF             FAC1_3      = FAC1_e+3   ; FAC1 mantissa3
00225      00B0             FAC1_s      = FAC1_e+4   ; FAC1 sign (b7)
00226
00227      00AC             str_ln      = FAC1_e   ; string length
00228      00AD             str_pl      = FAC1_1   ; string pointer low byte
00229      00AE             str_ph      = FAC1_2   ; string pointer high byte
00230
00231      00AE             des_pl      = FAC1_2   ; string descriptor pointer low byte
00232      00AF             des_ph      = FAC1_3   ; string descriptor pointer high byte
00233
00234      00AF             mids_l      = FAC1_3   ; MID$ string temp length byte
00235
00236      00B1             negnum      = $B1      ; string to float eval -ve flag
00237      00B1             numcon      = $B1      ; series evaluation constant count
00238
00239      00B2             FAC1_o      = $B2      ; FAC1 overflow byte
00240
00241      00B3             FAC2_e      = $B3      ; FAC2 exponent
00242      00B4             FAC2_1      = FAC2_e+1   ; FAC2 mantissa1
00243      00B5             FAC2_2      = FAC2_e+2   ; FAC2 mantissa2
00244      00B6             FAC2_3      = FAC2_e+3   ; FAC2 mantissa3
00245      00B7             FAC2_s      = FAC2_e+4   ; FAC2 sign (b7)
00246
00247      00B8             FAC_sc      = $B8      ; FAC sign comparison, Acc#1 vs #2
00248      00B9             FAC1_r      = $B9      ; FAC1 rounding byte
00249
00250      00B8             ssptr_l      = FAC_sc   ; string start pointer low byte
00251      00B9             ssptr_h      = FAC1_r   ; string start pointer high byte
00252
00253      00B8             sdescr      = FAC_sc   ; string descriptor pointer
00254
00255      00BA             csidx         = $BA      ; line crunch save index
00256      00BA             Asptl         = csidx   ; array size/pointer low byte
00257      00BB             Aspth         = $BB      ; array size/pointer high byte
00258
00259      00BA             Btmpl         = Asptl   ; BASIC pointer temp low byte
00260      00BB             Btmph         = Aspth   ; BASIC pointer temp low byte
00261
00262      00BA             Cptrl         = Asptl   ; BASIC pointer temp low byte
00263      00BB             Cptrh         = Aspth   ; BASIC pointer temp low byte
00264
00265      00BA             Sendl         = Asptl   ; BASIC pointer temp low byte
00266      00BB             Sendh         = Aspth   ; BASIC pointer temp low byte
00267
00268      00BC             LAB_IGBY      = $BC      ; get next BASIC byte subroutine
00269
00270      00C2             LAB_GBYT      = $C2      ; get current BASIC byte subroutine
00271      00C3             Bpntrl      = $C3      ; BASIC execute (get byte) pointer low byte
00272      00C4             Bpntrh      = Bpntrl+1   ; BASIC execute (get byte) pointer high byte
00273
00274    ;         = $D7      ; end of get BASIC char subroutine
00275
00276      00D8             Rbyte4      = $D8      ; extra PRNG byte
00277      00D9             Rbyte1      = Rbyte4+1   ; most significant PRNG byte
00278      00DA             Rbyte2      = Rbyte4+2   ; middle PRNG byte
00279      00DB             Rbyte3      = Rbyte4+3   ; least significant PRNG byte
00280
00281      00DC             NmiBase      = $DC      ; NMI handler enabled/setup/triggered flags
00282                   ; bit   function
00283                   ; ===   ========
00284                   ; 7   interrupt setup
00285                   ; 6   interrupt enabled
00286                   ; 5   interrupt happened
00287    ;         = $DD      ; NMI handler addr low byte
00288    ;         = $DE      ; NMI handler addr high byte
00289      00DF             IrqBase      = $DF      ; IRQ handler enabled/setup/triggered flags
00290    ;         = $E0      ; IRQ handler addr low byte
00291    ;         = $E1      ; IRQ handler addr high byte
00292
00293      00E2             irq_a_reg      = $E2      ; save A during IRQ
00294    ;         = $E3      ; unused
00295    ;         = $E4      ; unused
00296    ;         = $E5      ; unused
00297    ;         = $E6      ; unused
00298    ;         = $E7      ; unused
00299    ;         = $E8      ; unused
00300    ;         = $E9      ; unused
00301    ;         = $EA      ; unused
00302    ;         = $EB      ; unused
00303    ;         = $EC      ; unused
00304    ;         = $ED      ; unused
00305    ;         = $EE      ; unused
00306
00307      00EF             Decss         = $EF      ; number to decimal string start
00308      00F0             Decssp1      = Decss+1   ; number to decimal string start
00309
00310    ;         = $FF      ; decimal string end
Actually $E2 was added in my version, so it will also be unused in yours. Another large free memory area seems to be from $14 - $5A.
PostPosted: Sun Jan 07, 2018 7:44 pm
Thanks Klaus.
Isn't some code loaded in to page 0 somewhere?
If not, then that's more free than I expected - good stuff!
PostPosted: Sun Jan 07, 2018 9:12 pm
Yes, code is loaded at $BC-$D7, the get BASIC char subroutine. I think the big gap $14-$5A was originally reserved for the input buffer. But that was moved away from page zero in EhBASIC.
PostPosted: Mon Jan 08, 2018 7:07 pm
Users browsing this forum: No registered users and 52 guests
cron
