I couldn't readily find some 6502 code to convert a byte to hex string (basically, to show the contents of particular memory locations on an LCD screen, etc.) so have written my own. It does work. What does everyone think?
' Parameters:
' A - value to convert from byte to hex string
' Outputs:
' X - LSB character
' Y - MSB character
.byteTOhexstr
PHA
' grab the MSB and move to LSB
LSR A
LSR A
LSR A
LSR A
' if A is greater than &A then go to A-F
CMP #&A
BCS numstrMSB_AtoF
.numstrMSB_0to9
ADC #48
TAX
JMP numstrLSB
.numstrMSB_AtoF
CLC
ADC #55
TAX
' LSB
.numstrLSB
PLA
' grab the LSB by masking out the MSB
AND #&0F
CMP #&A
BCS numstrLSB_AtoF
.numstrLSB_0to9
ADC #48
TAX
JMP numstrLSB
.numstrLSB_AtoF
CLC
ADC #55
TAY
RTS
Have you looked at this code? It can convert a binary value to any of four radices, hex being one of them. The largest binary value that it can convert is $FFFFFFFF or (2^32)-1.
To convert a single byte to printable hexadecimal characters, you could use the following code:
It's a few bytes longer, but a few cycles faster (especially if you avoid the JSR), to look the nybble up in a table of "0123456789ABCDEF". I tend to go that route, since that's often an integral part of IO where I need to maximize speed.
There aren't any branches associated with the CMP instructiions. To convert to ASCII hex, a test for 0...9 should be followed by an ORA #$30 (or ADC #$30). But if the nibble is greater than 9, the adjustment for A...F needs to be applied instead.
He's using the cmp instructions for their carry side-effects, Michael. Combined with the BCD +6 adjustment, the carry flag provides just the right +7 to jump from '9' to 'A' in ASCII.
Hi, I want to change this code to be able to write on a screen 2 bytes number. It shows only first byte now, I should make a jump to PRHEX before making 4 LSR for sure, but despite trying it doesn't work, so I think there is something I forgot. Can you tell me what is wrong in my thinking?
; put this just before PRBYTE
BMI PRBYTE
; Subroutine to print a word in X (low byte) and A (high byte)
PRWORD JSR PRBYTE ;print high byte
TXA ;continue to print low byte
; continue with PRBYTE
Prior to "jsr print" I do not see any ldx and A is always loaded with $ba! The "bmi phex" is only necessary in the original context. I suppose $ff80 points to your print string utility.
You initialize Y with 0 and then attempt to write the characters of a hex word backwards to ($80)+0, ($80)+$ff, ($80)+$fe, ($80)+$fd.
Please note that you should ask this kind of questions in a separate thread in the newbies section with a link to where you found the original code. And remember to post your modifications from the beginning as what you say might not be what you actually have programmed.
