The README on his git repository states
... which seems to be what's happening - Address 0000 (PC) is presented 6 clocks after the 'reset' line is toggled low (shown by the marker), and the data for the instruction at that address appears on the next clock.
The CPU is linked through to the blockram just as you might expect:
module top
output [15:0] memAB,
output [7:0] memDO,
input clk,
input rst_n
// Instantiate the 64k of BlockRAM for main memory
wire memWE; // Write-enable
wire [7:0] memDI; // Data read from memory
ram mem_inst
.clk(clk),
.addr(memAB),
.we(memWE),
.di(memDI),
.do0(memDO)
// Instantiate the CPU
reg irq_n; // External in: IRQ
reg nmi_n; // External in: Non-maskable IRQ
cpu cpu_inst
.clk(clk), // System clock
.reset(~rst_n), // Active high reset
.DI(memDO), // Read: data @ (address)
.DO(memDI), // Write)
.AB(memAB), // Address bus
.WE(memWE), // Write-enable
.RDY(1'b1), // Pause the CPU if low
.IRQ(irq_n), // external IRQ if low
.NMI(nmi_n) // non-maskable IRQ if low
endmodule
And the blockram is a standard dual-ported inferred model that returns the data on the next clock:
module bram
parameter DATA = 8,
parameter ADDR = 16
// Port A
input wire clka,
input wire wea,
input wire [ADDR-1:0] addra,
input wire [DATA-1:0] dina,
output reg [DATA-1:0] douta,
// Port B
input wire clkb,
input wire web,
input wire [ADDR-1:0] addrb,
input wire [DATA-1:0] dinb,
output reg [DATA-1:0] doutb
// Shared memory
reg [DATA-1:0] mem [(2**ADDR)-1:0];
// Port A
always @(posedge clka)
begin
if (wea)
mem[addra] <= dina;
else
douta <= mem[addra];
end
// Port B
always @(posedge clkb)
begin
if (web)
mem[addrb] <= dinb;
else
doutb <= mem[addrb];
end
endmodule
[Edit: Hmm, I noticed that BRK is supposed to be 7 cycles, not 6. Perhaps it's a timing thing... I'm also a little concerned that 'S' is going to 'xx' as a consequence of state BRK3 writing to the register...]
Simon
