Kowalski Simulator Updates
I have been working on fixing bugs and adding features to the simulator. I am pleased to release v1.2.13 for everyone to use. Please let me know if you have any issues with this release.
Here is a summary of the issues I have collected and their current status: It has passed both of Klaus' test suites - the 6502 and the 65C02. I has also passed the timing test that BigEd created (details here -> viewtopic.php?f=8&t=3340&p=38584&hilit=kowalski#p38581 )
enjoy!
enjoy!
- Attachments
- 6502v1.2.13.zip
- (540.41 KiB) Downloaded 677 times
Re: Kowalski Simulator Updates
Thank you very much Daryl. Works like a charm!
- BigDumbDinosaur
enjoy!
enjoy!
For those interested, unused opcodes in 65C02 mode will be executed as NOP's using the appropriate operand modes. You can use them by using the .DB or .BYTE pseudo opcodes. Here's an example of using the undefined opcode $DB, which has an "absolute" addressing mode.
You can see in the disassembly window that the LDA #$36 at $1003 gets absorbed into $DB's operand. This trick allows you to call either top or val to load different values into address $56, in this example.
As a side note, the yellow pointer will not display on lines that do not contain valid opcodes in the source windows, but you can follow the pointer in the disassembly window. This is on my list to try to fix in the next revision.
The disassembly window will also jump when you move to address $1003 so that you will see the LDA #$36.
The command log will show the correct opcodes, similar to the disassembly window.
I hope everyone finds this useful, or at least understandable.
- BigDumbDinosaur
Thanks BDD,
I'll dig out the code and see if I can figure this out.
thanks!
thanks!
I downloaded a fresh copy of the 1.2.12 sources and compiled using the latest updates for Visual Studio 2017, and this test file also errors. Something has changed in the source since they were compiled by Michael. This will not be as easy to find as I had hoped.
I found the place where the local labels get defined and checked for duplication. I tried your source on the old 1.2.6 source and it works correctly. So, I compared the source for both versions and it appears Michal added a process level local variable.
I could not find any documentation on this but it appears from the source that a label using .. as a prefix might apply to this process level. Where any global label delimits the local label, it appears that a global label named 'proc' is used the delimit this new level. However, without testing it, I would assume that using 'proc' more than once would result in a duplicate label error.
I have added a condition test to the source where the error was occurring and it appears that local labels are working now.
Attached is the binary for new version 1.2.14.
I will post the source files shortly.
- Attachments
- 6502v1.2.14.zip
- (540.46 KiB) Downloaded 565 times
Kowalski source code containing 1.2.13 and 1.2.14 fixes for anyone interested.
- Attachments
- Simulator14.zip
- (5.37 MiB) Downloaded 648 times
- BigDumbDinosaur
Something that would be worth doing when time permits would be to reduce the amount of whitespace emitted in each line in the listing file. For example, four blanks separate the line number from the assembly address—that could be reduced to two blanks with no loss of readability. Similarly, three blanks could be removed from the whitespace that follows the bytes that have been generated for an instruction.
For example, here's how a line in the listing file looks right now:
04013 E303 BD 50 D9 .0000010 lda postmemc,x ;current memory count
Anyhow, thanks for tracking down and fixing the local labels error.
Glad to hear you POC sources compile now BDD. I will look into the list output. I use Windows notepad to view my listings and it does not wrap the lines, so the spacing doesn't affect me. If I can find where to adjust it, I'll post it here.
- barrym95838
It could be changed to:
Does anyone else prefer a different ordering, like so:
E303:BD 50 D9 `04013 .0000010 lda postmemc,x ;current memory count
Mike B.
As for rearranging the order, I can do that too, but do not want to create any forks for future releases, so we'll need a consensus from the group. I can create a one-time executable with that format if you would like.
It would allow a .lst file to be pasted directly into a Woz-style monitor.
Mike B.
Mike B.
I just realized that this will only work for instructions... any data declarations will fail as the assembler does not output a list of bytes for data sections. it would take a lot of time to dig deeper in the code to change that. It would be easier to build a stand alone executable that could take a binary image and convert that to a Woz friendly listing.
- Attachments
- 6502v1.2.14a.zip
- Reduced white space in the listing fie.
- (540.44 KiB) Downloaded 820 times
