Where can I learn the 6502 hardware and instruction set?
I want to learn the 56 instructions and the hardware like, registers, ALU or whatever. Where can I learn that?
- BigDumbDinosaur
Re: Where can I learn the 6502 hardware and instruction set?
- GARTHWILSON
- Forum Moderator
The best tutorial and reference I know of is the programming manual "Programming the 65816 including the 6502, 65C02, and 65802"" by David Eyes and Ron Lichty. It's not free anymore, but it's definitely worth the price. No 65xx enthusiast should be without it. The 65c02, BTW, has more instructions than the 56 number you gave (it's around 72), and more addressing modes too, and the 65816 has even more. If you're just getting into this, do not limit yourself to the original NMOS 6502's instruction set.
JenniferDigital
Another thing that might well help you is that the Kowalski simulator shows you information about the instruction at your text cursor as you edit. This means you're getting given little clues as you go.
Oh, and although it is Windows software it does seem to work under Wine.
A lot of people - including me - got started on other books. Rodnay Zaks' Programming the 6502 is a classic. It looks like Lance Leventhal also wrote one. I'm sure you can find a cheap secondhand copy, or a copy on line. The Advanced User Guide for Acorn's BBC Micro is also pretty good.
